I've looked at this several times, but with either dd-wrt Kong build 25090M or 25735M, I'm seeing iperf at nearly 33% higher with dd-wrt than using stock firmware.
At the moment I just have mobile clients that I can easily carry around, my laptop is pretty much a desktop at this point (external display, keyboard, and mouse). So I got an iperf3 app for my iPad Air 2 just for fun, installed the corresponding Windows version of iperf3 for the server end, and compared the 5GHz. throughput results for stock versus dd-wrt firmware in my living room. This is where I use my iPad the most. This is also the furthest point in my house from the R7000 router, so of most interest that I get good performance there.
What I saw was that the stock firmware ran around 65Mbps average, and the dd-wrt firmware ran around 85-90Mbps average. I was surprised, so repeated these tests several times, with pretty consistent results. Found this quite surprising, but repeatable.
I also checked out the RT-AC68P, and with RMerlin's firmware, it also ran around 65Mbps on average. I haven't yet tried dd-wrt on the RT-AC68P, but I suspect I would see comparably higher throughput with dd-wrt.
Anyways, just thought this was interesting, even though the tools are on the light and fluffy side *smile*. So guess what, I'm staying with dd-wrt on the R7000 for the moment *smile*. IPv6 even works well, until I reboot or power-cycle the router, at which point I lose my internet connection when the router comes back up. I guess that you can't have everything.
