R7000 UDP broadcasts to port 7423
paraplu
My Netgear R7000 seems to be broadcasting every second or so to UDP port 7423. This is currently happening with latest stock firmware, but happened earlier with older stock firmware as well.
Kong's DDWRT does not show this behavior.
I have reported this to Netgear Support but they also seem to be surprised. Still waiting for a clue.
Configured as Access Point only, with default settings.
Can somebody please explain what this is? Thanks in advance...
Using Wireshark on any device connected to my subnet, including wireless. Each showing a constant (1-second interval) UDP broadcast to mentioned port, originating from my R7000.
R7000 configured as an AP with single (WAN) port connection to Netgear switch; no other connections on remaining R7000' LAN switch ports.
This is the wireshark output from a wireless client (my R7000 being 192.168.1.5):
No. Time Source Destination Protocol Length Info
1 0.000000 192.168.1.5 255.255.255.255 UDP 215 Source port: 55764 Destination port: 7423
Frame 1: 215 bytes on wire (1720 bits), 215 bytes captured (1720 bits)
Ethernet II, Src: xx:xx:xx:xx:xx (xx:xx:xx:xx:xx), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 192.168.1.5 (192.168.1.5), Dst: 255.255.255.255 (255.255.255.255)
User Datagram Protocol, Src Port: 55764 (55764), Dst Port: 7423 (7423)
Data (173 bytes)
0000 4b 41 4e 4e 4f 55 25 4e 00 00 00 00 00 c4 04 15 KANNOU%N........
0010 5b bc b3 52 37 30 30 30 00 00 00 00 00 00 00 00 [..R7000........
0020 00 00 00 52 37 30 30 30 00 00 00 00 00 00 00 00 ...R7000........
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 31 2e 30 32 2e 34 31 00 00 .......1.02.41..
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 ................
0070 00 01 00 00 00 02 00 00 00 02 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 00 00 00 00 00 00 00 00 00 00 00 00 00 .............
OK, so the packet is on your LAN, not out your WAN.
what computer/thing is 192.168.1.5 on your LAN?
I'm seeing the same thing on my R7000 with the most recent firmware, also in AP mode and connected to a GS110TP switch. In addition, I'm seeing Spanning Tree Protocol broadcasts from the R7000 at regular intervals. I'd like to be able to turn both off, but don't see how.
I'm guessing the UDP 7423 broadcasts are related to USB/ReadyShare services etc., but all of those functions are disabled on my R7000. I'm using it strictly as an Access Point.
That's what I thought as well; ReadyShare. The "Basic" option cannot be disabled in the GUI. I have tried the readyshare downloadable utilities (USB control center, Vault) but these were not able to detect a device.
Maybe it relates to Netgear Genie; as this application detects the R7000 automatically.
Other netgear devices have the same: http://forum1.netgear.com/showthread.php?t=75139
D-Link devices seem to have something alike: http://www.dslreports.com/forum/remark,21224552
I also see UDP broadcast packets going out from the Netgear R7000 router (source is the router's IP address here), to 255.255.255.255 port 7423. I don't have any printers or USB stuff going on with my router, none of the USB stuff is enabled here. UPnP is also off. IPv6 advertising happens on other ports.
I wonder if this is really a USB-related thing that is left on whether you have any USB functionality or not. Lots of questions about this on the internet, no definitive answer. It doesn't really matter, since I can spare the bandwidth *smile*, just makes one wonder.
UPnP disabled?
Yes, as mentioned above.
Update: Just flashed Shibby's v122, and not seeing those UDP broadcasts that I saw with the latest stock firmware. Interesting.
7423/UDP is used by Netgear's USB Control Center and readyShare. it's unrelated to DLNA or UPNP.
Netgear Support replied that they are unable to simulate this issue in their lab. Weird.
Two questions:
1. is it possible to stop this broadcast?
2. is this broadcast having any influence on mobile wireless devices eg battery?
netgear's official reply:
It’s the readyshare print function. We currently do not have way to turn it off since we need to detect the printer attached without user to turn on feature from GUI.
i.e. USB printer "hotplug". Not sure that I want to pay the freight for that, shouldn't I have a choice? Okay, they can have it on, so give me the choice to turn it off *smile*.
Their answer seems to imply that they don't trust the average user that needs it to be able to turn it ON. Therefore, they can't give the advanced user the ability to turn it off.
Just tested: the same 3 second interval broadcast also happens with firmware 1.0.3.80, and also in media bridge mode.
Message to Netgear: please provide an option in the web interface to disable/enable this printer function. Better: give us telnet/ssh access.
