R7800 - How to block 1 device from Internet but not Network?
Restalfep
Is there a way to block one device on my network from internet access but still have it available on my local network? I was guessing under Attached Device to disable it, but it seems that would disable even local network access. Anyone know the best way to do this?
Thank you.
You can with the block services. I use that function for an old security camera DVR which has not had a firmware update in a long time, thus I blocked all traffic to it, where the only way for me to access it remotely, is the first VPN into the home network.
Go to Advanced > Security> Block Services.
Be sure to also assign the device a static IP.
Thanks. Using that method, would I leave ports blank or would I enter 1 to 65000 or whatever it is to block everything? I would want to make sure no way internet can ever get through to that device.
If you select "Service Type" = "ALL" it should populate all the fields automatically...
Protocol = TCP/UDP
Starting Port = 1
Ending Port = 65535
