R7800 jump back to 5ghz DFS Channel
NetgearR7800
Hi, i 'm still on stock fitmware 1.0.3.92 and i always wanna use Channel 100 in 5ghz and i get kicked very often because of an aiport in my town. Then i have to set Channel 100 again because there is no autochannel function for 5ghz in the UI. Is there a possibility to jump back after the 30 Minutes in the Voxel Firmware oder is there a autochannel function for 5ghz?
Thanks a lot for any information.
I used to have the R7800, but if you are using DFS channels, then this can happen, can you just use channel 36? for 5ghz band?
With Channel 36 i only get 50mbit of my 100mbit downspeed. 10mbit up is no problem. I tested all channels. Best and most stable is 100 with 40mhz bandwidth without HT160 with MIMO. I have a MediaTek Wi-Fi 6E MT7922 160MHz Wireless LAN Card. Tried the Microsoft and proprietary driver. With 2.4ghz i only also get only 50mbit down.
So the nicest would be to come back to 100 if i got moved to an other channel.
This my settings, and I get 1gbps in the 5ghz band, I enabled "Enable 160 MHz bandwidth in the 5 GHz band" also "MU-MIMO" and "Beamforming". For your 5ghz wifi channel 36 and Secondary VHT80 channel: 52 (DFS). Reboot and wait about 10 minutes, then try your wifi you can easily hit your 100mbps. I can easily hit 940mbps.
Hi Jberry, i tested all channels and 100 is the only stable for me. So at the moment the only solution is to set back 100 from time to time by hand.
With the latest kamoj addon (need voxel firmware installed first), you can change the country, and then select a different channel, I’m not too familiar which countries have what channels, but maybe something to look into to use a different channel than everyone else.
