R7800 Temperature
LeKeiser
Hello everyone,
Just curious, what is the temperature of your R7800?
Mine is between 52°C and 56° in a room at 22/23°C
I think it's perfect; spec wise.
I also have a cooler for laptops, I can gain about 6/8°C when I turn it on, but it makes some noise in the bedroom, so...
Mine is wall-mounted flat against a wall with the ports on top, and I'm currently getting 46°C at room temperature of 21°C.
My CPU load is currently 5% so not using much.
WiFi temperature is ath0 - 40°C and ath1 - 36°C
55°C right now, Core 0 is at 7%, Core 1 at 3%. Warmer than yours, room temp is 22°C. Weird...
As long as you don't hit 75°C or higher, you'll be fine. Turn the cooler on only when it's hot/heatwave
The key seems to be mounting the router vertically. Better airflow, lower temperatures. :)
root@HERMES:~$ cat /sys/class/thermal/thermal_zone*/temp
43
43
41
42
41
42
44
41
44
40
43
Room @ 21°C
Horizontal on top of laptop cooler.
Load is very low.
43
43
41
42
41
42
44
41
44
40
43
Room @ 21°C
Load is very low.
The cooler is on I presume? Even when mine is running, I never get those temps. Closer to 48°C, even when the router is "idle". Might be because the thermal paste is not applied properly on mine...
Another datapoint - and it sits horizontal on a USB powered laptop cooler.
root@R7800:/$ cat /sys/class/thermal/thermal_zone*/temp
42
43
41
42
43
41
42
42
43
40
44
56
55
53
53
55
54
55
54
55
53
56
Horizontal, on a wooden shelf, no cooler, room temp ~ 23C.
My cooler is off. I'll turn it on and check again in 1/2h :)
52
50
50
51
51
49
50
50
52
47
52
EDIT :
So 1/2h later with the cooler on :
49
46
47
46
46
47
47
47
47
44
48
A bit better, but is it worth it? I mean, the fans make some noise :O
But there is something I don't understand. When I use Kamoj's addon, I get this :
54°C at the same time.
So which temp is the right one?
Yes, all the time. Silent and not in a living room.
After the problems I had with my first R7800 (nvram resets), I got the cooler at the same time as the new one from RMA.
PS: I have not been able to read those temps from netdata yet. If someone was successful doing that, please share.
Looks like you are correct. As a quick test, I stood my router vertically on the front edge for a bit, and the temps dropped by a few degrees compared to when it was sitting horizontally.
50
49
48
50
51
50
49
50
49
53
Hello :)
What do you mean exactly?
Hello :)
Netdata is cool monitoring tool available from Entware.
You can monitor all kind of information from a simple web page (CPU, memory, network, and more).
Netdata is able to report temperature, but I have not been able to set it up correctly on the R7800. Got it to work on Odroid N2 and C2 for temps.
It is ok, but a little high... particularly in a cool room. Was your router doing intense CPU tasks?
If not, the airflow is not optimal. Is the router in a piece of furniture? Or a place without air circulation?
I would suggest to get a laptop cooler just to be sure and give a long life to your router :)
My temps run a bit higher in a cool room. Do we think these are ok?
Mine would always hover around 72 degrees C. I just propped up my router on two supports (to allow airflow around the sides and now it is down to 64 degrees C. I'm fine with that.
Thanks for the reply. No, it seems to sit around this temp all the time, regardless of what the task is. It is out in the open, but kind of tucked away in a corner. Perhaps isn't quite getting the circulation it needs. Will look into a small laptop cool, thanks for the tip. Would be a shame for it to give up the ghost before it's time.
I've done a bit more testing of this and I installed DD-WRT to test it against that.
With latest version of DD-WRT (28th August) I get between 41-47C (wall mounted)
With Voxel and Kamoj I'm getting 45-55C depending on room temp, humidity and CPU load.
The Netgear firmware seems to have more going on which is running the CPU higher regardless of CPU load compared to a more basic setup like DD-WRT
This would appear normal for the Netgear/Voxel firmware so nothing to worry about.
