R7800 Voxels firmware .. measure wan bandwidth
RMinNJ
In the RST_statistic.htm (internet port, show statics page) the Rx and Tx B/s do not increment. (Voxels 1.0.2.69)
Is there any place in Voxels firmware to measure the bandwidth in and out on the WAN port of the 7800. I had a program called networx that probed the router via upnp and gave the Mbit/s quite accurately.. but the program stopped working on my linux box (not related to the router firmware). Any other simple programs for linux that will probe the router stats?
It is not quite clear: do you intend to measure your speed (ISP) or just R7800 WAN capabilities (e.g. artificial environment when R7800 is connected by WAN port to your server by 1Gbps cable).
Speedtest by OOKLA included into WebGUI allows to measure the speed.
Other simple programs is e.g. iperf3 (available also in Entware). And of course practically all Linux allows to install iperf3. It could be used in artificial environment and in Internet. E.g.
https://speedtest.wtnet.de/
Download speed:
iperf3 -c speedtest.wtnet.de -p 5200 -P 10 -4 -R
Upload speed:
I myself do use iperf3 (artificial environment) for testing. Probably most accurate tool. See "man iperf3" for details and options.
There are other free iperf3 servers in Internet. E.g.
https://iperf.fr/iperf-servers.php
Or use e.g. speedtest-cli (by speedtest.net). But only WAN for real Internet connection environment.
https://packages.debian.org/buster/speedtest-cli
Voxel.
Kind of..
I rebooted my 7800 and the internet show statistics box is incrementing. Its in B/s though and I think its a total average over the whole up time of the router.
The networx program from Softperfect probes the router via upnp (it can do snmp also) and graphs the instantaneous Mbit/s downloaded and uploaded through the WAN port.
I can see how much of my wan is being used say by my kid watching a 4k youtube video. I saw for example that those Netflix previews as your flipping through titles burst to 60Mbit/s. My kid downloading an Xbox game would use m.y entire pipe. I've since upgraded from 100Mbit cable service to 200Mbit.
The data is from the router, one would think the router itself could display a current live rate for us.
Well, If you are interested in real-rime monitoring your router... There is a package in Entware: netdata.
netdata is a highly optimized Linux daemon providing real-time performance monitoring for Linux systems, applications and SNMP devices over the web.
It shows current load of router. E.g. network (WAN):
plus other resources.
etc. See e.g.
https://github.com/netdata/netdata/wiki
or
https://ahelpme.com/software/monito...phs-system-overview-cpu-memory-disks-and-nfs/
Could be installed on the router. Accessible from your browser e.g. http://192.168.1.1:19999
Voxel.
Cool ! seems like it will include the wan port in aggregate data.. So first I need entware installed.. just follow your tutorial.. Will netdata load down the router much ?
etc. See e.g.
or
Voxel.
Hi, unfortunately the netdata package is no longer available.... Also the opkg update command does not update:
root@GABSGEAR:/tmp/mnt/sda1/entware/bin$ opkg update
Downloading http://downloads.openwrt.org/attitude_adjustment/12.09-rc1/ipq806x/generic/packages/Packages.gz.
Collected errors:
* opkg_download: Failed to download http://downloads.openwrt.org/attitude_adjustment/12.09-rc1/ipq806x/generic/packages/Packages.gz: Error.
Location does not exist anymore. Nothing there for ipq806x. Any idea where I can get netdata for the R7800?
Thank you.
Weird, I'm getting this on a r7800
root@GABSGEAR:/tmp$ wget http://www.voxel-firmware.com/Downl...e-3x-Voxel/netdata_1.19.0-1_cortex-a15-3x.ipk
--2020-03-24 20:17:54-- http://www.voxel-firmware.com/Downl...e-3x-Voxel/netdata_1.19.0-1_cortex-a15-3x.ipk
Resolving www.voxel-firmware.com... 194.135.87.112
Connecting to www.voxel-firmware.com|194.135.87.112|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1581232 (1.5M) [application/vnd.shana.informed.package]
Saving to: 'netdata_1.19.0-1_cortex-a15-3x.ipk'
netdata_1.19.0-1_cortex-a15 100%[=========================================>] 1.51M 1.15MB/s in 1.3s
2020-03-24 20:17:56 (1.15 MB/s) - 'netdata_1.19.0-1_cortex-a15-3x.ipk' saved [1581232/1581232]
root@GABSGEAR:/tmp$ opkg install netdata_1.19.0-1_cortex-a15-3x.ipk
Unknown package 'netdata'.
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for netdata found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package netdata.
Thank you Voxel and Kamoj. Very interesting information. netdata is up and running (I had to create some directories myself though).
But please, can you give an overview of all different interfaces?
I have
ath0
ath1
br0
brwan
eth1
eth2
ethlan
ethwan
tap0
tun0
I have difficulties pinpointing them to what interfaces those exactly are.
Hope you can explain. TIA
WIFI:
ath0
ath1
eth1 # Not used
eth2 # Not used
BRIDGE:
br0
brwan
LAN:
ethlan
WAN:
ethwan
TUNNELS devies e.g. for OpenVPN:
tap0
tun0
Hey.. good deal. I never did install entware and netadata.. I had gotten the networx program working again on my linux box. Here is tonight with my kid watching a show on netflix and me watching FX
on sling..
So I wanted to see if I could get Entware installed and then install this Netdata app as well. I believe I got Entware installed by using Voxels readme file.
I was able to run use “/opt/bin/opkg update” and “/opt/bin/opkg upgrade”.
However when I got to try to get Netdata app installed, I'm getting the following:
--2020-03-31 14:35:08-- http://www.voxel-firmware.com/Downl...e-3x-Voxel/netdata_1.19.0-1_cortex-a15-3x.ipk
netdata_1 0%[ ] 0 --.-KB/s
netdata_1. 2%[ ] 35.04K 94.7KB/s
netdata_1.1 5%[> ] 85.95K 143KB/s
netdata_1.19 8%[> ] 124.13K 134KB/s
netdata_1.19. 13%[=> ] 204.73K 181KB/s
netdata_1.19.0 18%[==> ] 278.26K 208KB/s
netdata_1.19.0- 23%[===> ] 358.87K 230KB/s
netdata_1.19.0-1 29%[====> ] 455.02K 255KB/s
netdata_1.19.0-1_ 36%[======> ] 562.49K 281KB/s
netdata_1.19.0-1_c 44%[=======> ] 691.17K 311KB/s
netdata_1.19.0-1_co 54%[=========> ] 833.99K 344KB/s
etdata_1.19.0-1_cor 66%[============> ] 1021K 389KB/s
tdata_1.19.0-1_cort 83%[===============> ] 1.26M 454KB/s
data_1.19.0-1_corte 97%[==================> ] 1.47M 492KB/s
etanetdata_1.19.0-1_co 100%[===================>] 1.51M 496KB/s in 3.1s
2020-03-31 14:35:12 (496 KB/s) - 'netdata_1.19.0-1_cortex-a15-3x.ipk' saved [1581232/1581232]
root@R7800:/tmp$ opkg install netdata_1.19.0-1_cortex-a15-3x.ipk
Collected errors:
Let me know if I missed something...
you forgot the path with the command opkg install netdata_1.19.0-1_cortex-a15-3x.ipk, so it is probably using stock opkg instead of entware opkg.
you should have used /opt/bin/opkg install netdata_1.19.0-1_cortex-a15-3x.ipk
btw, normally /opt/bin/opkg install netdata should have also worked (i.e without first downloading the .ipk with wget)
Ok that worked. /opt/bin/opkg install netdata_1.19.0-1_cortex-a15-3x.ipk
I'm taking notes for future reference.
Is there anything else?
Should I be able to run it from a browser now? http://192.168.#.1:19999
And with that, its running. Wow. Sure is handy. Lots of info to check out.
Thank you very much for your help.
One last question, how can I update the ipk package. I see that NetData has an update. Something I need to run in telnet?
