R7800 vulnerbilities using Voxel firmware
rbanksy
Hi Voxel
Any chance of upgrading the following components in the R7800 firmware?
Critical
Netatalk OpenSession Remote Code Execution
Description
The Apple Filing Protocol (AFP) server running on the remote host is affected by a remote code execution vulnerability due to a buffer overflow condition when handling an OpenSession request. An unauthenticated, remote attacker can exploit this issue, via a specially crafted message, to execute arbitrary code.
Solution
Upgrade to Netatalk 3.1.12 or later.
Critical
MiniUPnP < 1.4 Multiple Vulnerabilities
Description
According to its banner, the version of MiniUPnP running on the remote host is prior to 1.4. It is, therefore, affected by the following vulnerabilities :
- An out-of-bounds read error exists in the ProcessSSDPRequest() function in file minissdp.c that allows an unauthenticated, remote attacker to cause a denial of service condition via a specially crafted M-SEARCH request. (CVE-2013-0229)
- A stack-based buffer overflow condition exists in the ExecuteSoapAction() function in the SOAPAction handler, due to improper validation of user-supplied input. An unauthenticated, remote attacker can exploit this, via a long quoted method, to cause a denial of service condition or the execution of arbitrary code.
(CVE-2013-0230)
Solution
Upgrade to MiniUPnP version 1.4 or later.
It may be within the closed source portion of the code so he can't do anything...?
