Solved R9000 iptables
BritinMA
Hello,
I have installed mini_snmpd today, and could only get it to work on the router itself, and not from a local machine on the LAN side; Turns out that in the loc2fw chain, snmp is blocked:
iptables -L loc2fw --line-numbers
3    DROP       udp  --  anywhere             anywhere             state NEW multiport dports snmp,snmp-trap
So after deleting that line, it's working.
iptables -D loc2fw 3
After a reboot, it obviously is blocked again; I could write a script to check for, and if found, delete that rule, but I wonder what sets iptables at boot, and can it be manipulated so that a reboot will not set up the block?
Any pointers are welcome!
Hello,
If you are using @Voxel firmware, you can simply add this line in /opt/scripts/firewall-start.sh (create the file if it does not exist):
After each reboot, or internal firewall restart (and when the iptables are being reset to default NG conf), this script is ran.
Hello!
I am absolutely using Voxel's firmware; It was remiss of me to not state it!
I was not aware of the /opt/scripts/firewall-start.sh script - that was most helpful. Thank you!
This is the code I've written; It provides a modicum of logic before the command.
linedel=$(iptables -L loc2fw --line-numbers |grep snmp-trap |awk {'print $1'})
if [ ! -z "$linedel" ]; then
    iptables -D loc2fw $linedel
fi
