RAM usage AC86U
D_Day
Does anyone know the average usage of RAM for the AC86U?
I’ve had the AC68U and was running about 150mb most of the time but the AC86U is running at 425mb with the same apps running.
I just want to know if something is wrong or everything is fine.
Normal. It reports cached memory as used so make sit hard to track actual free RAM.
Take a look at the Tools>Sys Info page for a better breakdown of usage.
Many thanks for your reply :)
It’s not really ‘using’ it. Just the reporting is different.
You can count cached RAM as free, look at the Sys Info page I mentioned and minus the cached value off and you’ll find it’s likely using under 200Mb.
It leaves me on about 257Mb, I’m happy with that :)
