Random fact- NAND flash endurance on recent Wifi 7 routers
RMerlin
Asuswrt-Merlin dev
Staff member
Fun fact: some of the Wifi 7 (I only checked my RT-BE92U and RT-BE96U, it's possible they use it for many Wifi 7 models) use the MX30LF2G28AD SLC NAND flash, which can handle up to 60K erase cycles.
Keep in mind that every write cycle in NAND has to erase a entire block and then rewrite the data due to how NAND works... which is important for tasks that write to the flash - this likely would mean the third party scripts that do a fair amount of writes...
My most recent project used Winbond 32MB SPI-NOR - and it should be good for 100K write/erase cycles per their docs - and since it's NOR, it's only the specific addresses needed - even there, we kept writes to a minimum, storing config data only - logs were all in RAM... I think part of the endurance on these devices are because of automotive usage, where lifetime considerations are more than a couple of years...
Should also mention that the NAND part @RMerlin mentions - this is an SLC part, which is the best that you can get for NAND - most of your SSD's now days are MLC (or more) - but they have over-provisioning and a flash controller to manage the wear...
NAND has a lot of performance advantages over NOR, but NOR has good things as well - always a tradeoff...
K random disconnect xt12 ASUS Wi-Fi 6
