Random lag on devices?
TimothyM96
So, I have a Ac66U at the end of my home, and the AC68U as the main router. When I'm near the AC68U, or connected to it, I may browse fine for 10 minutes, then maybe for a minute it is just dead...for example...I was trying to refresh my Snapchats. It just loaded and loaded and loaded. Then it finally loads. Same goes for webbrowsing, anything.
I have adjusted channels, settings, and anything that comes to my mind but I"m clueless. All my devices will give me this random one minute of internet drop (though the connection doesn't drop).
Is there anything I can try?
Im in the same boat for the past 6 hours.
What firmware are you using? Have you used Asus DDR upgrade tool to OC your Ram from 553 to 666??
Still having this issue. The internet just simply stalls and will start loading after about 30 seconds, and I don't know why. Both AC68U and AC66U have latest firmwares. Note, devices don't drop the connection, it just stalls.
