It's difficult to define and it also depends on which band you're talking about - 2.4 GHz or 5 GHz?
At 2.4 GHz, ac is equivalent to n - I'm sure someone will correct me if I'm wrong. So the 2.4 GHz comparisons here should work:
http://www.smallnetbuilder.com/lanw...113-asus-rtn66u-dark-knight/1235-asus-rtac68u
which shows the N66U ahead, especially in uplink.
You won't be able to compare 5 GHz results head-to-head though, as the N66U can't use the higher ac rates. What you want to see is both routers tested using n clients on 5 GHz - this data would be quite hard to find.
The latest N66U firmware reduces the range compared to the AC66U/AC68U. This is something Asus is aware of and will be looking into in the future.
Is it by a significant amount....something like 20% ?
Around 10 dB when I did a few tests with it compared to the old N66 firmware. No idea how it compares to the AC68U output, I didn't compare them at the time.
That's a quite significant, considering that I have decent coverage right now on your 3.0.0.4.374.33 (3-Oct-2013) firmware, I look forward to the fixed drivers mentioned by RogerSC (SDK5 firmware versions)....any chance that will happen still in 2013 ?
If using my firmware you can just switch to the sdk5 version and everything will be fine. If you are using my regular 374.33 build, then the coverage it gives you *is* the reduced one, which means it would still be sufficient for your needs.
No idea what are Asus's plans - they are currently busy stabilising the newly released AC68U, as well as dealing with the new features they recently introduced. All I know is this is something that's still on their radar at this time.
Welcome To SNBForums
