nikkaidmka
I have made a NAND-dump with flashcatusb from working Linksys router and programmed new NAND chip. CFE booting fine. But when image start booting I see lot of ECC errors like below:
any suggestions?
Thanks!
PS: probably have to set ECC settings on flashcatusb, but can't find right one
Initalizing switch low level hardware.
Software Resetting Switch ... Done.
Waiting MAC port Rx/Tx to be enabled by hardware ...Done
Disable Switch All MAC port Rx/Tx
devinfo: block read
devinfo: data is valid!
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Enable Switch MAC Port Rx/Tx, set PBVLAN to FAN out, set switch to NO-STP.
Loading 192.168.1.254:94908.dtb image at address 0x08000000..
Loading FW .....
Loading failed.: CFE error -21
boot from flash, mfg mode = -1
Loading FW .....
Booting from latest image (address 0x00100000, flash offset 0x00100000) ...
Uncorrectable ECC Error: intr 0x50, addr=0x0015fe00, blk=10,
Uncorrectable ECC Error: intr 0x50, addr=0x002bfe00, blk=21,
Decompression LZMA Image OK!
Entry at 0x0000000000080000
bcm63xx_nand ff801800.nand: uncorrectable error at 0x680800
ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 11:2048, read only 2048 bytes, retry
any suggestions?
Thanks!
