Reboot scheduler lost in cronjob after reboot.
miazza
Hi all. After having updated amtm to the latest version (might be just a cohencidence), every time that I set reboot scheduler this is written in cronjob:
The following cron jobs are active (cru l):
_____________________________________________
 .---------------- minute       (0 - 59)
 |  .------------- hour         (0 - 23)
 |  |  .---------- day of month (1 - 31)
 |  |  |  .------- month        (1 - 12) OR Jan,Feb,mar ...
 |  |  |  |  .---- day of week  (0 - 6) Sunday = 0 or 7, OR Sun,mon,Tue ...
 *  *  *  *  *  command to be executed  #job_name#  ( * = every ... )
 10 7 * * Sun /bin/sh /jffs/addons/amtm/sc_update.mod -run #amtm_ScriptsUpdateNotification#
 */11 * * * * /jffs/scripts/wicens.sh cron #wicens#
 */5 * * * * /jffs/scripts/ChkWAN.sh #WAN_Check#
 */2 * * * * /etc/openvpn/server1/vpn-watchdog1.sh #CheckVPNServer1#
 00 2 * * Wed /bin/sh /opt/share/diversion/file/update-bl.div reset #Diversion_UpdateBL#
 20 5 * * * /bin/sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLogs#
 20 17 * * * diversion count_ads count #Diversion_CountAds#
 30 1 * * Wed /bin/sh /opt/share/diversion/file/stats.div #Diversion_WeeklyStats#
 12,42 * * * * /jffs/scripts/spdmerlin generate #spdMerlin_generate#
 5 3 * * * /jffs/scripts/spdmerlin trimdb #spdMerlin_trimDB#
 10 * * * * /jffs/scripts/uiDivStats generate #uiDivStats_generate#
 1 0 * * * /jffs/scripts/uiDivStats trimdb #uiDivStats_trim#
 */2 * * * * /jffs/scripts/uiDivStats querylog #uiDivStats_querylog#
 4-59/5 * * * * /jffs/scripts/uiDivStats flushtodb #uiDivStats_flushtodb#
 0 2 * * * service reboot #amtm_RebootScheduler#
 Press Enter to return to menu
After a reboot the last row disappears.
 10 7 * * Sun /bin/sh /jffs/addons/amtm/sc_update.mod -run #amtm_ScriptsUpdateNo        tification#
 00 2 * * Wed /bin/sh /opt/share/diversion/file/update-bl.div reset #Diversion_U        pdateBL#
 20 5 * * * /bin/sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateL        ogs#
 30 1 * * Wed /bin/sh /opt/share/diversion/file/stats.div #Diversion_WeeklyStats        #
How can I fix the point ?
You need to add the cru a command to one of the scripts executed on boot. I suggest /jffs/scripts/init-start, if it exists.
If it doesn't exist create it with the following content:
#!/bin/sh
cru a amtm_RebootScheduler "0 2 * * * service reboot"
Follow with
chmod a+rx /jffs/scripts/init-start
Why not just use the scheduler in Administration>System?
#!/bin/sh
Why not use the scheduler in Administration>System?
The scheduler in the Administration is not reliable and it is a well know bug that the rooter remains stuck off and need to be unplugged from the wall in order to reset. If this happens when I am in vacation ... this is a problem.
What you described is a manual way to solve the issue but in the past this was somehow authomatically done by the amtm script dedicated to this job. Did something change ?
Init start is correctly configured:
miazza@RT-AC86U:/jffs/scripts# cat init-start
#!/bin/sh
exit 0
cru a amtm_RebootScheduler "0 2 * * * service reboot" # Added by amtm
I don't know. It's just the way I've done things for a time now. I use init-start for things that only need executing once at every reboot.
After reading up I do exactly the same as the reboot scheduler script, just manually. But my method doesn't disappear.
init-start is well configured but the crontab does not resist a reboot:
#!/bin/sh
exit 0
After reboot the init-start is there but the crontab is not anymore containing the job:
ASUSWRT-Merlin RT-AC86U 386.14_2 Sun Nov 17 19:18:53 UTC 2024
miazza@RT-AC86U:/tmp/home/root# cd /jffs/scripts
#!/bin/sh
exit 0
miazza@RT-AC86U:/jffs/scripts# crontab -l
10 7 * * Sun /bin/sh /jffs/addons/amtm/sc_update.mod -run #amtm_ScriptsUpdateNot        ification#
00 2 * * Wed /bin/sh /opt/share/diversion/file/update-bl.div reset #Diversion_Up        dateBL#
20 5 * * * /bin/sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLo        gs#
mmmm, something wrong there then.
What's the contents of init-start after a reboot? What about execute permissions?
Via ssh does "/jffs/scripts/init-start" create the cronjob?
The problem is the presence of the exit 0 line in that script. Delete the init-start script and setup the scheduler again.
I do not know how the exit 0 entered in the init-start script.
I removed the file and created a new one from amtm.
After reboot the service reboot is now the first line:
miazza@RT-AC86U:/tmp/home/root# crontab -l
#!/bin/sh
Thank you
