CakeQOS Recommendation?
kapekohicafe
Hi Guys,
I know there has been a lot of questions about CakeQOS configuration. Also, I know that it is supposed to be set and forget. But, i just wanted to know if do you have any recommendation in my current configuration.
100MB/100MB DL/UL
Fiber connection
Looks good, except for WAN packet overhead possibly.
What's your ISP/Modem connection type? May have to google it. Then click the red down arrow and select a preset, or if unsure use the "Conservative option".
I have Fibre, it's a PPPoE VDSL2 connection. So I use "WAN packet overhead: 30, MPU: 0, Mode: Normal"
May take some bufferbloat testing to find your ideal values.
Good luck!
Hi Alchemy, thanks for responding to my question. I really appreciate it.
Have a great day!
Over the next few weeks, you may want to use the avg weekly numbers from spdMerlin to set your cake speed numbers.
