Recommendations for 100m2 flat?
uwotm8
My ASUS RT-AC87U has served me well for years, but I’ve just learned that it’s EOL.
Despite this week’s ASUS incident, I wouldn’t be opposed to getting another piece of ASUS equipment.
My main hurdle is that my fiber equipment is housed within a concrete utility cupboard. Each room has Ethernet, but all cables lead to this cupboard.
I’ve not had any noticeable signal problems with the one RT-AC87U, though I’m wondering if it is worth going mesh with wired backhaul? Or would the close proximity between equipment just lead to interference between them?
Gone down a rabbit hole of reviews, so would really appreciate some real world experience
Definitely no need for mesh in that space. Just use the ethernet off the wan port to put it anywhere outside the cupboard and you should be all set.
Just because your router is EOL doesn't mean you have to replace it right away. Maybe once there is a vulnerability and they don't update the firmware (a major one they may still release an update for it). But ax86u seems to be highly recommended here. But may want to use yours til the wifi7 models are more common at which point there should be deals on the ax ones.
Thanks for the reply! I’ll look into the ax86u and see if I can convince my better half that it won’t be an eyesore under our television
You can put it pretty much anywhere you want (other than inside a concrete cupboard) to cover 100m2/1000ft2, unless there are a lot of concrete walls. Central and higher is better but can usually find a compromise where it won't stick out.
If you have an ISP router and just want wifi, various companies (Ubiquiti, TP Link, Engenius, others) make flat white ceiling mounted units that blend pretty well, not sure if you'd be able to run a wire to that though.
