recommendations for changing routers/APs
al2813
I currently run a setup with the following components:
- ground floor: ISP cable modem router catering also for NAT/DHCP and wifi for the ground floor. Off it I have two switches - one next to the router in the home office and another one in the living room for several multimedia devices.
- First floor 2nd TV room : A Linksys EA8500 router wired to the cable modem/router and acting as an AP for the the first floor and a hub for some connected multimedia devices.
I bought the Linksys router initially in an attempt to cover the entire house with one WIFI AP, but this did not really work. After moving things around I got to the conclusion that I need to have 2 APs in the house in order to guarantee decent coverage everywhere. To complete the picture, I have a lot of connected clients both wired and WIFI (I would say 30-40 overall between phones, tablets, computers, streamers, consoles, TVs, STBs etc.). I do not do anything fancy with the routers. Despite my good intentions, I remain a newbe with very little spare time, so except the odd port forwarding for online gaming, my routers are pretty much default.
For a long time I have been wanting to change things. Basically I would like to remove all routing/WIFI functions from my ISP cable modem router and put in bridge mode. I would like than to have one router handling all wired routing in the house, and place dedicated APs to handle WIFI. For the APs the choice is made. I will get a couple of Unifi AC-PROs. This will allow me to have a single WIFI network for the house, as well as improve the placement of the APs benefiting from the PoE functionality of the Unifi. For the router I still need to decide. I thought of getting a Ubiquity router, but am a bit scared being a newbe. Can my EA8500 take on the task (WIFI part will be disabled of course)? Any advice welcome...
If the EA8500 can handle it or not will really come down to what speeds your ISP offers. If you are running sub-100Mbps, just about any modern consumer router will probably handle the basics. I have no experience with the various Ubiquiti routers so I can't really chime in there.
At my house, I run a pfSense box as my firewall/router. I have 1Gbps Internet and most consumer routers can't quite handle that.
At my in-laws whose network I also support, it is an Asus RT-N66U with the WiFi disabled. They only have 35Mbps Internet so even the N66 is way overkill for them.
Indeed I forgot this data point. My current speed is 200/10. There are talks of higher speeds available in 2018 (I live in Belgium), but living outside the city don't think I'll get them immediately.
A quick Google search of the EA8500....well...if you already paid that much for it, you might as well use it. Unless you can sell it easily to recoup money, I see no reason to buy anything else for the basic tasks you have identified.
