1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Recommending dhcp server
Discussion in 'Asuswrt-Merlin' started by EventPhotoMan, Feb 17, 2020.
  1. EventPhotoMan
    EventPhotoMan Very Senior Member
    Mar 29, 2018
    664
    Any suggestion in software to install on my Windows 10 machine?
    I’m trying to see if the dhcp server on the ASUS Rt-ac86u is not re-leasing correctly or the Lifx bulbs are the issue.
    since I’m getting no help from Lifx what-so-ever.
  2. L&LD
    L&LD Part of the Furniture
    Dec 9, 2013
    12,617
  3. EventPhotoMan
    Mar 29, 2018
    664
    I think you missing my point. I'm looking for software to run as a DHCP server on my windows computer to release the ASUS router of its duty.
    All bing is showing my is how to configure your windows based device to a dhcp server...
    I found this thou, https://sourceforge.net/projects/dhcpserver/
  4. L&LD
    Dec 9, 2013
    12,617
  5. EventPhotoMan
    Mar 29, 2018
    664
    Or my other option is to use Wireshark and sniff what the DHCP server is doing....
    I just want to listen to discover, offer, request and acknowledgement.
  6. Chewie420
    Chewie420 Occasional Visitor
    Feb 16, 2020
    24
    You can install pi-hole and config it as your DHCP server. You can't install on Windows 10 though. Might want to make a Virtual System if you want to test.
  7. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    11,714
    UK
    You could just run tcpdump on the router running the DHCP server (assuming it has Entware installed).
