Refresh Assigned IP around the DHCP list
Igor
"/Advanced_DHCP_Content.asp", Menu "Manually Assigned IP around the DHCP list (Max Limit : 64)"
What command can be used to display a list of assigned DHCP in the terminal?
From the Home Assistant smart home, I control the availability of devices. In my network there are two ASUS RT-AX68U (fw 388.1) routers in Mesh mode and one ASUS RP-N12 in access point (AP) mode. After a while, devices connected to the AP are not visible as available on the AX68U router and, as a result, are not visible in the Home Assistant. At the same time, in fact, everything works. But! If I open the "/Advanced_DHCP_Content.asp" page, then the devices become visible.
How can I simulate running "Manually Assigned IP around the DHCP list" from the terminal without wget?
