Hi everyone,
I suspect that the 2.4Ghz radio in my RT-AC66U has finally bit the dust. No complaints though - It has performed almost flawlessly for an impressive 6 1/2 years! So I'm back to ask for advice before making a purchase (just as I did back then). I've read some posts and it looks like an RT-AX58U or RT-AX86U could be a good upgrade. I've kicked around the idea of a mesh (or multiple routers) in the past to improve performance in a few bad spots of my house, but wasn't keen on moving away from Merlin firmware features for an off-the-shelf mesh product. Here are my stats:
HOUSE:
- 2700sq Ft
- 3 levels (2 floors & finished basement)
USAGE:
- About 22 clients total (3 rokus, tablets, phones, laptops, desktops, etc.) pretty usual stuff
- 2 adults / 2 children
- 200Mbit service (may upgrade some day - no hurry)
USAGE:
- Up to 8 devices in use at any given time
- Not much IOT (I have trust issues with Alexa/Google/Siri, etc)
- Although I do have a Honeywell smart thermostat - early model though, so I'm pretty sure they can't hear my thoughts.
- Streaming TV
- Kids remote school
- I work from home - lots of video conferences, etc - workplace VPN is the bottleneck there.
- No heavy file sharing, but periodic semi-large upload/download for work (1-2Gb)
- Plex media server
- Periodic remote desktop for work and personal use (helping family)
HARDWARE:
- Asus RT-AC66U running Merlin 378.56_2
- Motorola SB6141 Docsis 3 modem (still working perfectly from what I can tell)
- Most stationary clients in house are hard-lined (1 router, 2 switches)
- - - 8 port Switch next to router - all ports in use
- - - 8 port Switch in family room for TVs, game consoles, etc
PAST PERFORMANCE:
- Very good signal strength over 2.4Ghz almost everywhere except kitchen and 1 bedroom upstairs
My preferences in general are stability and features ...I know they don't always live well together.
Not afraid to pay for quality - $250-$300 if necessary, but money isn't burning a hole in my pocket either if that's overkill.
I intend to install Merlin again - was very happy with the improvements last time.
I will probably follow @OzarkEdge 's install notes - they look well thought out.
I plan to start with one router - but may consider adding a second in mesh mode (or AP?) if it will help my range without causing issues.
- Could I possibly use the old AC on 5Ghz or will that force the new AX to fall back to lower speeds?
Any comments or advice would be greatly appreciated - thanks in advance.
HOUSE:
- 2700sq Ft
USAGE:
USAGE:
- Streaming TV
- Plex media server
HARDWARE:
PAST PERFORMANCE:
