remote access enabled and ddns started by a custom script
Geoffster
hi I'm the attached log at 2256 it shows remote access being enabled and ddns turning on with a custom script. amongst other things
i don't have either of these enabled and I'm concerned how they are starting,
and who has access to my router to do this?
  • messages.log.txt
This would probably been better posted in the Merlin forum, since it appears you're using an ASUS RT-AX58U w/ Merlin.
May  5 12:05:07 kernel: Linux version 4.1.52 (merlin@ubuntu-dev) (gcc version 5.5.0 (Buildroot 2017.11.1) ) #1 SMP PREEMPT Wed Jun 22 14:57:00 EDT 2022
As far as Mastiff is concerned ...
I can also see you have various AddOns (e.g., Diversion) and custom scripts installed as a result.
Jun 25 20:15:29 Diversion: Starting Entware and Diversion services on /tmp/mnt/30gbusb
It's NOT uncommon for an AddOn to configure and start other processes or custom scripts.
So it's NOT as if the router is a *clean*, factory fresh install. It's been modified. If it was, I could better understand your concern.
