Remotely access ssh of a device connected with a VPN client
cowst
I am setting up a RPi as access point routing all the traffic through a VPN, and in case the service doesn't work for some reason, the traffic is blocked.
There are 2 exceptions:
1 - traffice within a couple of LANs should work
2 - the RPi should be accessible through ssh from outside
The problem I am having is that ssh traffic comes in from eth0 but tries to get out from tun0 due to openvpn pushed routes.
I tried to mark the traffic in iptables mangle, the route to a table that force back eth0. (I also tried plenty of other things but obviously failed to hit the right one :) )
Can anybody suggest how to achieve what I need?
Following are the commands I am currently using, and the status of things.
WAN_IP=$(wget -q -O - http://ipecho.net/plain)
iptables -A INPUT -i eth0 -p tcp --dport 22 -m state --state NEW,ESTABLISHED -j ACCEPT
iptables -A OUTPUT -o eth0 -p tcp --sport 22 -m state --state ESTABLISHED -j ACCEPT
iptables -A PREROUTING -i eth0 -t mangle -p tcp --dport 22 -j MARK --set-mark 1
iptables -A INPUT -s 192.168.2.0/24 -d 192.168.2.0/24 -j ACCEPT
iptables -A OUTPUT -s 192.168.2.0/24 -d 192.168.2.0/24 -j ACCEPT
iptables -A INPUT -s 192.168.1.0/24 -d 192.168.1.0/24 -j ACCEPT
iptables -A OUTPUT -s 192.168.1.0/24 -d 192.168.1.0/24 -j ACCEPT
iptables -A FORWARD -i wlan0 -o tun0 -j ACCEPT
iptables -A FORWARD -i tun0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
iptables -A OUTPUT -o eth0 ! -d $WAN_IP -j DROP
ip rule add fwmark 1 table 1
ip route add 0.0.0.0/0 table 1 dev eth0
pi@raspberrypi:~ $ ip route list
0.0.0.0/1 via 10.8.8.1 dev tun0
default via 192.168.2.1 dev eth0
default via 192.168.2.1 dev eth0  metric 202
10.8.8.0/24 dev tun0  proto kernel  scope link  src 10.8.8.27
128.0.0.0/1 via 10.8.8.1 dev tun0
185.145.38.236 via 192.168.2.1 dev eth0
192.168.2.0/24 dev eth0  proto kernel  scope link  src 192.168.2.74  metric 202
192.168.3.0/24 dev wlan0  proto kernel  scope link  src 192.168.3.1
pi@raspberrypi:~ $ ip route list table 1
default dev eth0  scope link
pi@raspberrypi:~ $ ip rule
0:   from all lookup local
32765:   from all fwmark 0x1 lookup 1
32766:   from all lookup main
32767:   from all lookup default
pi@raspberrypi:~ $ sudo iptables -L -v -n -t mangle
Chain PREROUTING (policy ACCEPT 759 packets, 71678 bytes)
pkts bytes target     prot opt in     out     source               destination
390 27656 MARK       tcp  --  eth0   *       0.0.0.0/0            0.0.0.0/0            tcp
dpt:22 MARK set 0x1
Chain INPUT (policy ACCEPT 759 packets, 71678 bytes)
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 709 packets, 74730 bytes)
Chain POSTROUTING (policy ACCEPT 709 packets, 74730 bytes)
Chain INPUT (policy ACCEPT 446 packets, 51142 bytes)
419 29604 ACCEPT     tcp  --  eth0   *       0.0.0.0/0            0.0.0.0/0            tcp dpt:22 state NEW,ESTABLISHED
33  6533 ACCEPT     all  --  *      *       192.168.2.0/24       192.168.2.0/24
0     0 ACCEPT     all  --  *      *       192.168.1.0/24       192.168.1.0/24
0     0 ACCEPT     all  --  wlan0  tun0    0.0.0.0/0            0.0.0.0/0               0     0 ACCEPT     all  --  tun0   wlan0   0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT 494 packets, 49499 bytes)
324 36968 ACCEPT     tcp  --  *      eth0    0.0.0.0/0            0.0.0.0/0            tcp spt:22 state ESTABLISHED
16  1723 ACCEPT     a
dpt:22 MARK set 0x1
16  1723 ACCEPT     a
dpt:22 MARK set 0x1
16  1723 ACCEPT     a
You are better off setting up a VPN server less complicated
https://www.snbforums.com/threads/h...th-asus-routers-380-66-6-updated-07-05.33638/
Are you suggesting that I create an openvpn server in the router hiding the RPi?
In that case, it is a shirtty Vodafone Station Revolution that allows only a few protocols (not openvpn), and even they don't work properly.
That with DDNS was the first thing I tried.
I could connect with PPTP, but then nothing really worked, I could load google.com 1 time out of 10, it seemed to timeout most of the times, maybe DNS issues, couldn't figure because the amount of complaints about that router swallowed whatever I was searching :)
If I had my Asus N66U it would have been already done (I use it at home with both openvpn client and server)
If you suggested to install openvpn server on the RPi, it wouldn't work as well, because as my SSH enters from eth0 and goes out from tun0, the same would happen to the openvpn negotiation. So I have to make the routing work in order to do anything reaching it from eth0 (I could install a GUI on it and Teamviewer, but I would be just a coward :D ).
If somebody feels like helping with the PPTP on the crappy router, that would do for me as well :)
get a good router and install VPN server. Not over RPi
I appreciate the suggestion, but I am looking for a SW solution.
I know that money can work around this problem. :)
