Repeated errors in log AC86U 384.19
Sonofdavidsfather
I keep getting the errors I pasted below in my log. I noticed them starting a few weeks ago. I am not seeing any pattern to events preceding the errors or following the errors. They aren't happening at consistent times. Does anyone have any ideas?
I did do a WPS NVRAM reset, formatting USB stick, and formatting jffs last night. The errors started cropping back up after all of that again.
Jan 21 10:10:57 kernel: dcd[17517]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 21 10:10:57 kernel: pgd = ffffffc002e46000
Jan 21 10:10:57 kernel: [00000000] *pgd=0000000009870003, *pud=0000000009870003, *pmd=0000000017406003, *pte=0000000000000000
Jan 21 10:10:57 kernel: CPU: 1 PID: 17517 Comm: dcd Tainted: P O 4.1.27 #2
Jan 21 10:10:57 kernel: Hardware name: Broadcom-v8A (DT)
Jan 21 10:10:57 kernel: task: ffffffc01daf5540 ti: ffffffc0047a0000 task.ti: ffffffc0047a0000
Jan 21 10:10:57 kernel: PC is at 0xf7100f44
Jan 21 10:10:57 kernel: LR is at 0x1dc74
Jan 21 10:10:57 kernel: pc : [<00000000f7100f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 21 10:10:57 kernel: sp : 00000000ffa07df8
Jan 21 10:10:57 kernel: x12: 000000000009ff08
Jan 21 10:10:57 kernel: x11: 00000000f63ff024 x10: 00000000000a02ac
Jan 21 10:10:57 kernel: x9 : 00000000f63ff870 x8 : 00000000000a0764
Jan 21 10:10:57 kernel: x7 : 00000000f63ff8a8 x6 : 00000000000a075e
Jan 21 10:10:57 kernel: x5 : 0000000000000000 x4 : 00000000f63ff854
Jan 21 10:10:57 kernel: x3 : 0000000000000000 x2 : 00000000ffa07dd4
Jan 21 10:10:57 kernel: x1 : 000000000007c66c x0 : 0000000000000000
Jan 21 10:05:41 kernel: dcd[17182]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 21 10:05:41 kernel: pgd = ffffffc0101c8000
Jan 21 10:05:41 kernel: [00000000] *pgd=0000000003bf0003, *pud=0000000003bf0003, *pmd=0000000009006003, *pte=0000000000000000
Jan 21 10:05:41 kernel: CPU: 1 PID: 17182 Comm: dcd Tainted: P O 4.1.27 #2
Jan 21 10:05:41 kernel: Hardware name: Broadcom-v8A (DT)
Jan 21 10:05:41 kernel: task: ffffffc013e76080 ti: ffffffc0156d0000 task.ti: ffffffc0156d0000
Jan 21 10:05:41 kernel: PC is at 0xf7400f44
Jan 21 10:05:41 kernel: LR is at 0x1dc74
Jan 21 10:05:41 kernel: pc : [<00000000f7400f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 21 10:05:42 kernel: sp : 00000000ffa3ac58
Jan 21 10:05:42 kernel: x12: 000000000009ff08
Jan 21 10:05:42 kernel: x11: 00000000f66ff024 x10: 00000000000a02ac
Jan 21 10:05:42 kernel: x9 : 00000000f66ff870 x8 : 00000000000a0764
Jan 21 10:05:42 kernel: x7 : 00000000f66ff8a8 x6 : 00000000000a075e
Jan 21 10:05:42 kernel: x5 : 0000000000000000 x4 : 00000000f66ff854
Jan 21 10:05:42 kernel: x3 : 0000000000000000 x2 : 00000000ffa3ac34
Jan 21 10:05:42 kernel: x1 : 000000000007c66c x0 : 0000000000000000
Jan 21 10:04:50 kernel: dcd[15019]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 21 10:04:50 kernel: pgd = ffffffc010e23000
Jan 21 10:04:50 kernel: [00000000] *pgd=0000000009063003, *pud=0000000009063003, *pmd=0000000009b9b003, *pte=0000000000000000
Jan 21 10:04:50 kernel: CPU: 1 PID: 15019 Comm: dcd Tainted: P O 4.1.27 #2
Jan 21 10:04:50 kernel: Hardware name: Broadcom-v8A (DT)
Jan 21 10:04:50 kernel: task: ffffffc0170634c0 ti: ffffffc00bf78000 task.ti: ffffffc00bf78000
Jan 21 10:04:50 kernel: PC is at 0xf6eb2f44
Jan 21 10:04:50 kernel: LR is at 0x1dc74
Jan 21 10:04:50 kernel: pc : [<00000000f6eb2f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 21 10:04:50 kernel: sp : 00000000ffd28bf8
Jan 21 10:04:50 kernel: x12: 000000000009ff08
Jan 21 10:04:50 kernel: x11: 00000000f61ff024 x10: 00000000000a02ac
Jan 21 10:04:50 kernel: x9 : 00000000f61ff870 x8 : 00000000000a0764
Jan 21 10:04:50 kernel: x7 : 00000000f61ff8a8 x6 : 00000000000a075e
Jan 21 10:04:50 kernel: x5 : 0000000000000000 x4 : 00000000f61ff854
Jan 21 10:04:50 kernel: x3 : 0000000000000000 x2 : 00000000ffd28bd4
Jan 21 10:04:50 kernel: x1 : 000000000007c66c x0 : 0000000000000000
ColinTaylor
Part of the Furniture
The "dcd Tainted" errors have been discussed for years. IIRC the current thinking is that it's caused by conflict between AiProtection and certain Merlin add-ons.
Sonofdavidsfather
Thank you very much for the info. With as long as those errors were, I wasn't sure what to search for. "DCD Tainted" is pulling up plenty of results. I run AI Protection, Skynet, and Diversion. I am pretty sure I didn't start seeing these until I retired my PiHole and switched to Diversion. Diversion is more important to me than the AI Protection. So I will go ahead and turn off the AI Protection.
ColinTaylor
I don't know whether my memory of this is correct, and I don't have that model of router. So if you could make a follow up post letting us know if that fixes the problem I'm sure it would help others.
Jack Yaz
It's usually pixelserv (well, the alias interface) conflicting with AiProtection. Disabling the latter may help, i can't recall, but disabling pixelserv stops the error completely.
Sonofdavidsfather
Disabling the AIProtection alone didn't do it. I had to go ahead and withdraw from the TrendMicro agreement in the Admin/Privacy tab. Since then no errors.
I might turn those back on, since TrendMicro is also behind the AdaptiveQoS and Parental Controls. I am going to give it a little time to see how things go without the Qos, and I should be able to use the porn blocking lists on Wally3ks page in Diversion to cover the parental controls.
Sonofdavidsfather
I tried to turn AIProtection back on after the 386.1 update. I am still seeing the same errors. So it looks like the same bug is still in the Trend Micro stuff on the 386 codebase.
