Hi all,
First time poster here, and I have tried searching for answers to my question, coming up empy.
My current network setup is simple, I have one Netgear WNDR3700 (v1) router running OpenWrt. On this router I have set up two wireless networks, a main network and a guest network. The guest network is then isolated (running a different IP range) from the main network.
These two wireless networks run the same channel and BSSID (being on the same radio), but has different ESSIDs (naturally). Both use WPA2 PSK, but the passwords are of course different.
Now, this setup works like a charm, but I need to extend the wireless range of both wireless networks, and I want to do this with just one additional wireless device. I am unsure if such a device exists. Regular repeaters/extenders seems to allow for only adding one particular SSID that you want to repeat/extend, but I want to extend both of these networks.
I could probably buy another router (that supports multiple SSIDs) and install a third-party firmware to it, but is there any standard device that could do the job? This one is advertised as supporting Multi-SSID, but I can't see from the docs if it is possible to do what I want with it:
http://www.tplink.com/en/products/details/?categoryid=239&model=TL-WA901ND
Any advice would be greatly appreciated!
