SOLVED Replaced RT-N66U, one computer won't connect wireless
Hello
After some thunder my old RT-N66u died on me. I've been happy with it so I got another one that arrived today.
Both the old one and the new one used/uses the newest firmware. The problem I experience after setting up the new router is that one of the computers (the one I used to setup the new network) will not connect to the wireless network. Only wired works. Wireless works fine on my other computer and on my android phone.
The pc I experience this problem on has a Atheros AR9002WB-1NG wireless network adapter and it says “trying to authenticate” and nothing more happens. I doubt it’s something wrong with the card since it worked fine with my other N66u.
Can it be a IP or MAC issue? Anyone knows how I can fix this?
Thank you for Your time
Hello
