Scribe Request for log snippets
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
Jack Yaz
Part of the Furniture
Hi, can anyone post a snippet of one of their logs that goes through scribe? I modded the message format ages back and don't remember how it used to look...I have ideas for a uiScribe update
elorimer
The standard syslog-ng output is this:
Jun 12 15:42:01 RT-AC86U spdMerlin: Starting speedtest using using auto-selected server for WAN interface
Jun 12 15:42:29 RT-AC86U spdMerlin: Speedtest results - Download: 200.41 Mbps (data used: 366.0 MB) - Upload: 36.54 Mbps (data used: 29.2 MB)
Jun 12 15:42:29 RT-AC86U spdMerlin: Connection quality - Latency: 14.14 ms (0.53 ms jitter) - Packet Loss: 0.0%
I massage my format like this because I collect logs from other devices:
destination messages {
    file("/opt/var/log/messages" template("${R_DATE} ${HOST} ${MSGHDR}${MESSAGE}\n") );
With this result, not much different than the regular one (no pid)
Jun 11 22:00:01 RT-AC86U uiDivStats: Starting stat update
Jun 11 22:00:28 RT-AC86U uiDivStats: Stats updated successfully
Jun 11 23:00:01 RT-AC86U uiDivStats: Starting stat update
Jun 11 23:00:30 RT-AC86U uiDivStats: Stats updated successfully
Jun 11 23:59:03 RT-AC86U dn-vnstat: Attempting to send summary statistic email
Jun 11 23:59:05 RT-AC86U dn-vnstat: Email sent successfully
And here is the native message generated before syslog-ng becomes active (no host):
May  5 01:05:09 syslogd started: BusyBox v1.25.1
May  5 01:05:09 kernel: klogd started: BusyBox v1.25.1 (2021-05-19 23:12:52 EDT)
May  5 01:05:09 kernel: Booting Linux on physical CPU 0x0
May  5 01:05:09 kernel: Linux version 4.1.27 ([email protected]) (gcc version 5.3.0 (Buildroot 2016.02) ) #2 SMP PREEMPT Wed May 19 23:52:54 EDT 2021
May  5 01:05:09 kernel: CPU: AArch64 Processor [420f1000] revision 0
May  5 01:05:09 kernel: Detected VIPT I-cache on CPU0
May  5 01:05:09 kernel: alternatives: enabling workaround for ARM erratum 845719
Jack Yaz
thanks, i modded mine to include priority, it seems
Jun 12 17:13:37 RT-AC86U debug networkmap: Error unlocking 0: 9 Bad file descriptor
Jun 12 17:13:42 RT-AC86U warning YazFi: YazFi v4.2.1 completed successfully
Jun 12 17:16:34 RT-AC86U warning YazFi: Downloading latest version (v4.2.1) of YazFi
Jun 12 17:16:36 RT-AC86U warning YazFi: YazFi successfully updated - restarting firewall to apply update
Jun 12 17:16:36 RT-AC86U notice rc_service: service 32272:notify_rc restart_firewall
JGrana
Here are a few from the standard syslog-ng catalog
wlceventd.log
Jun  7 12:18:10 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(534): eth6: Assoc B2:C2:E1:BA:CF:D0, status: Successful (0)
Jun  7 12:18:31 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(486): eth6: Disassoc B2:C2:E1:BA:CF:D0, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jun  7 12:18:52 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(505): eth6: Auth B2:C2:E1:BA:CF:D0, status: Successful (0)
Jun  7 12:18:52 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(534): eth6: Assoc B2:C2:E1:BA:CF:D0, status: Successful (0)
Jun  7 12:19:11 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(486): eth6: Disassoc B2:C2:E1:BA:CF:D0, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jun  7 12:23:15 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(505): eth6: Auth B2:C2:E1:BA:CF:D0, status: Successful (0)
Jun  7 12:23:15 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(534): eth6: Assoc B2:C2:E1:BA:CF:D0, status: Successful (0)
Jun  7 13:12:58 RT-AX88U-26A8 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 5C:41:5A:40:D7:F3, status: 0, reason: Disassociated due to inactivity (4)
and a custom log of an AX58U mesh node:
Mar 27 23:37:26 RT-AX58U-E058 syslog-ng[2033]: Log statistics; processed='src.internal(src#2)=89', stamp='src.internal(src#2)=1616881046', dropped='global(internal_source)=0', queued='global(internal_source)=0', dropped='dst.udp(log_server#0,udp,192.168.1.1:514)=70', processed='dst.udp(log_server#0,udp,192.168.1.1:514)=12312', queued='dst.udp(log_server#0,udp,192.168.1.1:514)=0', written='dst.udp(log_server#0,udp,192.168.1.1:514)=12242', processed='global(msg_clones)=0', processed='global(payload_reallocs)=5657', processed='destination(d_syslogng)=54', processed='destination(log_server)=12382', processed='global(sdata_updates)=0', processed='destination(messages)=5276', queued='global(scratch_buffers_count)=2', processed='source(s_lr_daily)=0', processed='center(queued)=19505', processed='destination(d_logrotate)=42', processed='source(s_lr_status)=42', processed='center(received)=7148', processed='destination(d_firewall)=0', processed='global(internal_queue_length)=0', processed='destination(d_wlceventd)=1751', processed='source(src)=7106', queued='global(scratch_buffers_bytes)=512'
Mar 27 23:39:01 RT-AX58U-E058 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar 27 23:39:01 RT-AX58U-E058 wlceventd: wlceventd_proc_event(469): wl1.1: Deauth_ind 68:72:C3:6E:2E:F4, status: 0, reason: Unspecified reason (1)
Mar 27 23:39:01 RT-AX58U-E058 wlceventd: wlceventd_proc_event(505): wl1.1: Auth 68:72:C3:6E:2E:F4, status: Successful (0)
Mar 27 23:39:01 RT-AX58U-E058 wlceventd: wlceventd_proc_event(534): wl1.1: Assoc 68:72:C3:6E:2E:F4, status: Successful (0)
Mar 27 23:39:01 RT-AX58U-E058 hostapd: wl1.1: STA 68:72:c3:6e:2e:f4 IEEE 802.11: associated
Mar 27 23:39:01 RT-AX58U-E058 hostapd: wl1.1: STA 68:72:c3:6e:2e:f4 RADIUS: starting accounting session 9190B8A13FC7A2A4
Mar 27 23:39:01 RT-AX58U-E058 hostapd: wl1.1: STA 68:72:c3:6e:2e:f4 WPA: pairwise key handshake completed (RSN)
