Reset the WiFi settings to default
MonkY
Hello everyone!
Does anyone know if there is a posibility to reset all the WiFi settings (for both 2.4Ghz and 5Ghz) to default, without changing anything else to router settings? I need to do that as i was playing a lot in the past months with the WiFi settings trying to get the best, but now it's a mess (sometimes on some devices i get like 2-3 times lower speeds).
Is there a command i could run in the shell, to reset only the WiFi settings? I can't fully reset the routers, as there are tons of DHCP reserved IP's (over 100 of them). Or maybe, i could just save the DHCP list and reset fully, then only load the list?
Btw, I am running Merlin custom firmware 380.65_4 (i have 3 Asus routers, 2 of them using Merlin, and one is Asus oficial only - RT-AC68U + RT-AC87U and RT-AC1200G+).
Thank you in advance!
