Solved Reset Wireless Settings RT-AC68U
muffintastic
Is there anyway of resetting the wireless in the router via SSH without nuking the entire router?
If you mean resetting the wireless settings to their default values then you could try this at you own risk. I haven't tested it.
nvram show | awk -F= '/^wl/ {print $1}' | xargs -n1 nvram unset
nvram commit
service reboot
when you say 'reset' do you mean reset wireless parameters to default settings OR do you simpy want to restart the wireless driver and radios on the the router? if the latter, then SSH into the 68U and issue the following command: service restart_wireless
