Restart DHCP without reboot?
werkstrom
Is there a way to restart the DHCP server without rebooting the router? Troubleshooting THIS issue with DHCP not responding and want to eliminate or confirm the DHCP service.
/Henrik
CaptnDanLKW
I suppose you could also enact a restart by changing a DNS setting on the LAN or WAN page or some DHCP parameter like lease time.
netware5
The easiest way is to install scMerlin script. It will facilitate easy restart of major services including the DHCP.
JGrana
I second this recommendation. Besides restarting DHCP, you can restart many of the services. Both from the WebUI and (my typical usage) from the CLI.
Forget to log out of the WebUI on one computer in your house? No problem, ssh in and restart httpd.
Make a change to ntp or chrony.conf? - a quick scmerlin and restart timeserver. For the life of me I can never remember the correct "service restart" commands.
Last, I can't explain in detail, but the Busybox "reboot" command is IMHO, not a good way to correctly reboot the router. "service reboot" must be doing some other magic. Again, scmerlin takes care of this ;-)
