1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Restore Setting from RT-AC88U to RT-AX88U
Discussion in 'Asuswrt-Merlin' started by ShagBark, Dec 5, 2019.
  1. ShagBark
    ShagBark New Around Here
    Dec 5, 2019
    4
    Been a lurker for a bit here and a Merlin user for about 6 months.
    Can I backup my settings on my old AC88U to restore on my new AX88U? Curious if anyone has any experience with this. I have a lot setting that I rather not have to redo manually unless I have to. Being they don't seem that much different I'm thinking it will work. Looking for any ideas on this.
  2. skeal
    skeal Part of the Furniture
    Apr 30, 2016
    3,627
    Saskatchewan
    No.
  3. skeal
    Apr 30, 2016
    3,627
    Saskatchewan
    Two different linux versions, two different design platforms, etc.
    ShagBark likes this.
  4. skeal
    Apr 30, 2016
    3,627
    Saskatchewan
    Also AX88U is 64bit and AC88U is 32bit.
    Butterfly Bones and ShagBark like this.
  5. ShagBark
    Dec 5, 2019
    4
    Understood. Fast reply thanks.
    Anyone have any suggestions on how I can do this. Only thing I came up with is pull up both web interfaces on 2 monitors, grab a drink and mirror the settings manually.
    adampk17 likes this.
  6. skeal
    Apr 30, 2016
    3,627
    Saskatchewan
    Screen shots work real nice as well.
    Butterfly Bones likes this.
  7. ShagBark
    Dec 5, 2019
    4
    Good point... any program to take screen shots automatically of all the setting pages? There are a lot of settings in the Merlin/Asus web interface to change.
  8. skeal
    Apr 30, 2016
    3,627
    Saskatchewan
    I use "awesome screenshots" for chrome and also "full page screen capture" for chrome. Both are extensions and free without added crap.
  9. skeal
    Apr 30, 2016
    3,627
    Saskatchewan
    Also you probably don't really need every page backed up. Backup the stuff you don't know from memory.
  10. Butterfly Bones
    Butterfly Bones Very Senior Member
    Apr 10, 2017
    1,089
    USA
    ShagBark and dave14305 like this.
  11. dosborne
    dosborne Senior Member
    May 11, 2019
    397
    /dev/null
    I print to PDF all important pages. Makes it super easy to pull something up as reference or reconfigure after a reset.
    royarcher and ShagBark like this.
  12. SheikhSheikha
    SheikhSheikha Regular Contributor
    Mar 20, 2019
    70
    The Desert
    A handy tool to capture all your configuration tabs is Snagit
    ShagBark and L&LD like this.
