You can reset the router via the button on the back and then reconfigure it from scratch - but keep in mind that the default router IP will be 192.168.1.1 - maybe the same as your main router - so better connect it via cable with a laptop (or standalone PC) to configure it at first.How to revert from Mediabrige to Wireless router mode.
I can't connect to webinteface to Mediabridged router (rt_ac56u), rt-ac68u is wireless router mode)
okay that was what I thought. I hoped to let it go. But if that's the only possibility then.You can reset the router via the button on the back and then reconfigure it from scratch - but keep in mind that the default router IP will be 192.168.1.1 - maybe the same as your main router - so better connect it via cable with a laptop (or standalone PC) to configure it at first.
thanks!Try using Asus's Device Discovery tool, downloadable from their support site.
Welcome To SNBForums
