[Review] Asus RT-AX3000 / RT-AX58U
Jayce Ooi
Author's Note: The original review can be found at my blog - Asus RT-AX3000 Review @ JayceOoi.com.
Hi everyone, meet Asus AX3000 WiFi 6 router. Asus RT-AX3000 also known as RT-AX58U at certain regions. It is powered by 1.5 GHz tri-core processor. Loaded with WPA3 support, Advanced Parental Controls and AiProtection Pro network security powered by Trend Micro. And compatible with ASUS AiMesh WiFi system. It comes with 4 Gigabits LAN and USB 3.1 Gen 1 port. 2 X 2 wireless connection with 160 MHz channels. Having 256MB Flash and 512MB of RAM. Alright, let’s have a closer look…
Thanks for watching. Peace…
HWDan
What's your preference between the RT-AX82U and the RT-AX58U ? It seems like your numbers are a bit better for the AX82U.
rahulgarg
Did you notice any major difference in performance between AX56u vs AX58u?
edit: Particularly when using 80Mhz?
scajjr2
Had to replace a AC86U so decided to give the AX58U a try. Got an Intel AX200 M.2 card for my laptop. Speed is really good. Did a Acronis backup ( about 35Gb in size) to a Synology NAS on our home network (1Gb speed) and got an average of 490/mbps, hardwired I get about 700 so I'm pleased.
Got a 2nd 58U to replace our other 86U (used as access point) and a couple more AX200 cards for the upstairs computers that usually connect to the AP.
Sam
Kiwipaul
I am also looking to replace my RT AC86U - so do we think that the RT-AX58U or even a 56U will be a good step up? Hoping that it will receive lots of upgrades etc from Asus as the WiFi 6 standard matures.
rahulgarg
Sam
Can you comment on how far the laptop was from AX58u? Also, what is the link speed shown and whether 160MHz is active?
Jayce Ooi
Not really. AC86U is a very good router. Unless you have a lot of AX devices now. Else no point to upgrade it.
John Fitzgerald
@Jayce Ooi
Question: What is the current CFE version being used for a stock setup on the AX58U.
