ROG STRIX GS-AX3000 Firmware
Turb-z
Is it me or is this router been forgotten about as there has been no updates since August 2021
You and all GS-AX3000 owners. It is strange indeed because the same hardware GS-AX5400 has much newer firmware available.
Just be patient. A lot of work is happening with Asus routers in the last year and they have a lot of models.
Is there anything that isn't working on your GS-AX3000?
This. Many of us are getting broken 388 firmware. You are not missing much.
Same question.
I badly need wireguard support.
Is there any chance it will be added?
And can I do something by myself?
Welcome to the forums @bundes.
If you 'badly' need WG support, consider purchasing a router that supports it today. Although I would be surprised if you really 'need' WG when other options (OpenVPN) is available.
Sure, there is always a 'chance' it may be added. But waiting for something when/if you need it today isn't the solution.
Have you used Better Search (top of page) to search the forums on what you may be able to do, now?
I am currently trying to figure out what I can do but it looks like this router is not supported by all these beta options or I didnt understand how it works.
Thanks I checked that but it didnt really help. I see some people have wireguard in vpn fusion but they have to go 388 firmware as I understand. 386 is the latest for this router so far. So unless someone suggests 'non-obvious' solution wait is the only option.
Try Better Search with your own key words. ;)
