Already have an RT AC68U (primary) and RTAC 66U (AP), plus a Securifi Almond + to play with (Extender)
Iv had some wierdness (loading the web UI) with the 66 esp post firmware update, even after setting back to factory defaults.. Sometimes it doesn't like to take a flash.. .. Am pondering either getting another AC68 (perhaps the P flavor and use it as the primary while putting the older 68U in place of the 66... Or get the 88 when its released and replace the 68 with that and roll the 68 over to where the 66 was and use it as an AP.. Some have mentioned that useing the 68s as a matched set tends to have less issues and a bit better performance than the mixed networking, even if its only primarily an AP..
-J
-J
