Here's my setup:
I'm using a DSL modem.
Connected my N66U to it.
2 desktops hard-wired to the N66U.
2 laptops on wifi.
Randomly--I will lose complete connectivity.
No access to LAN. WAN--wifi or wired.
I've restored to factory settings.
Restarted machines, routers, cable modems etc.
I've even purchased another router and set that up...same thing happened there too. 2-3 days things work..then randomly I lose all connectivity.
I have setup my network as 192.168.1.1 with 255.255.255 as the subnet and 192.168.1.1 as the gateway. All this works when things are going smoothly.
I've searched but havent found anything that would explain this.
Nothing seems to help.
If I direct connect any of the PC's to the DSL modem and dial out...that works...but networking seems to be an issue.
So is the problem with something in the DSL modem that is throwing things off? I've changed 2 routers---both cant have the same issue?
K
2 laptops on wifi.
K
