H
hungarian
Guest
Hi all
I have a problem/question.
First my problem/setup
Our house has 2 stories. Upstairs is a WLAN/Router/Modem from Sagem.
Downstairs I have a PC, Istar NMT which are connected to each other by a plus network card in the PC, I am streaming from the pc via CABLE, no router nothing in there. The PC is connected to the router/modem/wlan by WIFI and working fine. The nmt streaming via cable works fine, even in HD. I can NOT wire the system though the house (upstairs to downstairs) by wire WIFI is my only chance and working fine.
What I plan to do:
From the upstairs wifi/modem/router I would like to Powerline downstairs, into a router. Connect, PC (for streaming to the NMT), NMT (streaming there AND getting internet connection to the NMT without having the PC running for internet connection).
The PC WIFI connection stays as is, as it works fine.
So the final question is: can I route the signal from my upstairs router by means of Powerline into a downstairs router (or switch) on which the nmt, the pc are connected (wire). The pc streaming to the NMT runs trough that wired router or switch (no Powerline). The internet connection to the NMT works by means of Powerline. Later on I might add a NAS to the router (might....)
The point why I ask this question is, that the router and Powerline stuff costs me quite some, and once bought it would be difficult to give it back.
Please let me know if you think if this would work, adn if yes or no, please point why(not). Dont get me wrong, I will trust your opinion, but I would like to understand fully what I am doing.
Thank you for reading, and even more thanks you^s for replying
Cheers
H
What I plan to do:
Cheers
H
