G
GuruGuy
Guest
Not sure if this is the right place to ask, please move if a more appropriate place is warranted.
Few questions about the Router Ranker.
Love the drop down that allows sorting changes and then shows #1, #2, so on.
Is there a graph that also accompanies this? It's nice that they are ranked, but a graph showing all the results for each drop down would be an outstanding feature too.
For example sorting by range shows the scoring order highest to lowest. If there was a graph you could see the exact differences between each. The same for each of the other choices in the drop down. I realize you could drill down on each one shown and read the review, but having them all on the graph would tremendously make things easier comparison wise.
Or even including the relevant number in its ranking box would help. Sorta like already done on the chart page where for example you show 2.4 throughput and then in the section below each item shows the actual throughput number.
On the rankings page, whatever you are sorting by, include the relevant data in the item below so you can quick compare.
