Hi, I am new to this forum but I am happy to see it is very much alive so thanks for the reply.
Currently I am running the latest native firmware:
3.0.0.4.384_20308-gead790e. But I am considering a move to AsuswrtMerlin considering it would support AiMesh and solve the issue. And of course, the extra features are surely an interesting add on for me as well.
I am using an RT-AC88U (and potentially an RT-AC68U on top lateron).
I am connected to the internet behind a cable modem/router, Docsis 3, for which I do not know the brand. The MAC address starts with 5C:35:3B. The internet tells me this would be a "Compal Broadband Networks Inc." router.
It is a router, indeed, and I cannot set up a static IP address in that router. I notice that the lease time of the WAN IP@ is 3600 seconds but this, as well, is a parameter that is not available to users. I could try specifying a fixed IP@ at Asus side as indeed his IP@ does not change too often but not sure if this would work: their DHCP might consider "no requests, so let's cut off access".
I already changed the DHCP query frequency at ASUS side to "Normal" rather than "aggressive", but this didn't seem to help.
Main question is, of course, if the ASUS is reacting properly. My previous router didn't have this logging capability so the problem may not have been visible, but alternatively, my previous router (Linksys E4200) could cope with it in a better way?
Below is the log of yesterday: the problem appeared 3 times (I skipped the log of 11:37 the same day). Around 13:26 I had 2 events in a row, then got silent for the rest of the day.
Feb 4 13:26:28 WAN Connection: ISP's DHCP did not function properly.
Feb 4 13:26:28 DualWAN: skip single wan wan_led_control - WANRED off
Feb 4 13:26:29 nat: apply redirect rules
Feb 4 13:26:33 WAN Connection: Ethernet link up.
Feb 4 13:26:33 rc_service: wanduck 26312:notify_rc restart_wan_if 0
Feb 4 13:26:34 wan: [deconfig] udhcpc done[286]
Feb 4 13:26:36 wan: [wan0_hwaddr] == [10:7B:44:AF:04:58]
Feb 4 13:26:37 wan: [deconfig] udhcpc done[286]
Feb 4 13:26:40 rc_service: udhcpc 3123:notify_rc start_firewall
Feb 4 13:26:40 miniupnpd[29776]: shutting down MiniUPnPd
Feb 4 13:26:41 wan: finish adding multi routes
Feb 4 13:26:41 rc_service: udhcpc 3123:notify_rc stop_upnp
Feb 4 13:26:41 rc_service: waitting "start_firewall" via udhcpc ...
Feb 4 13:26:41 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 4 13:26:41 miniupnpd[3159]: version 1.9 started
Feb 4 13:26:41 miniupnpd[3159]: HTTP listening on port 58446
Feb 4 13:26:41 miniupnpd[3159]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 4 13:26:42 rc_service: udhcpc 3123:notify_rc start_upnp
Feb 4 13:26:42 rc_service: waitting "stop_upnp" via udhcpc ...
Feb 4 13:26:42 miniupnpd[3159]: shutting down MiniUPnPd
Feb 4 13:26:43 start_ddns: update
WWW.ASUS.COM dyndns, wan_unit 0
Feb 4 13:26:43 WAN Connection: WAN was restored.
Feb 4 13:26:43 miniupnpd[3164]: version 1.9 started
Feb 4 13:26:43 miniupnpd[3164]: HTTP listening on port 55580
Feb 4 13:26:43 miniupnpd[3164]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 4 13:26:43 ddns update: ez-ipupdate: starting...
Feb 4 13:26:43 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 4 13:26:46 ddns update: Asus update entry:: return: HTTP/1.1 299 |Invalid IP format| 192.168.0.212^M Date: Sun, 04 Feb 2018 12:26:42 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 4 13:26:46 ddns update: retval= 1, ddns_return_code (,299)
Feb 4 13:26:46 ddns update: asusddns_update: 1
Feb 4 13:26:59 rc_service: udhcpc 3123:notify_rc start_firewall
Feb 4 13:26:59 miniupnpd[3164]: shutting down MiniUPnPd
Feb 4 13:27:00 dhcp client: bound 192.168.0.212 via 192.168.0.1 during 3600 seconds.
Feb 4 13:27:00 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 4 13:27:00 miniupnpd[3254]: version 1.9 started
Feb 4 13:27:00 miniupnpd[3254]: HTTP listening on port 58566
Feb 4 13:27:00 miniupnpd[3254]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 4 13:27:30 WAN Connection: ISP's DHCP did not function properly.
Feb 4 13:27:30 DualWAN: skip single wan wan_led_control - WANRED off
Feb 4 13:27:30 nat: apply redirect rules
Feb 4 13:27:35 WAN Connection: Ethernet link up.
Feb 4 13:27:35 rc_service: wanduck 26312:notify_rc restart_wan_if 0
Feb 4 13:27:36 wan: [deconfig] udhcpc done[286]
Feb 4 13:27:38 wan: [wan0_hwaddr] == [10:7B:44:AF:04:58]
Feb 4 13:27:38 wan: [deconfig] udhcpc done[286]
Feb 4 13:27:41 rc_service: udhcpc 3308:notify_rc start_firewall
Feb 4 13:27:42 miniupnpd[3254]: shutting down MiniUPnPd
Feb 4 13:27:42 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 4 13:27:42 wan: finish adding multi routes
Feb 4 13:27:42 rc_service: udhcpc 3308:notify_rc stop_upnp
Feb 4 13:27:42 rc_service: waitting "start_firewall" via udhcpc ...
Feb 4 13:27:42 miniupnpd[3343]: version 1.9 started
Feb 4 13:27:42 miniupnpd[3343]: HTTP listening on port 54984
Feb 4 13:27:42 miniupnpd[3343]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 4 13:27:43 WAN Connection: WAN was restored.
Feb 4 13:27:43 rc_service: udhcpc 3308:notify_rc start_upnp
Feb 4 13:27:43 rc_service: waitting "stop_upnp" via udhcpc ...
Feb 4 13:27:43 miniupnpd[3343]: shutting down MiniUPnPd
Feb 4 13:27:44 start_ddns: update
Feb 4 13:27:44 ddns update: ez-ipupdate: starting...
Feb 4 13:27:44 miniupnpd[3349]: version 1.9 started
Feb 4 13:27:44 miniupnpd[3349]: HTTP listening on port 46235
Feb 4 13:27:44 miniupnpd[3349]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 4 13:27:45 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Feb 4 13:27:47 ddns update: Asus update entry:: return: HTTP/1.1 299 |Invalid IP format| 192.168.0.212^M Date: Sun, 04 Feb 2018 12:27:44 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Content-Type: text/html; charset=UTF-8^M ^M
Feb 4 13:27:47 ddns update: retval= 1, ddns_return_code (,299)
Feb 4 13:27:47 ddns update: asusddns_update: 1
Feb 4 13:28:01 rc_service: udhcpc 3308:notify_rc start_firewall
Feb 4 13:28:01 dhcp client: bound 192.168.0.212 via 192.168.0.1 during 3600 seconds.
Feb 4 13:28:01 miniupnpd[3349]: shutting down MiniUPnPd
Feb 4 13:28:02 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 4 13:28:02 miniupnpd[3440]: version 1.9 started
Feb 4 13:28:02 miniupnpd[3440]: HTTP listening on port 48340
Feb 4 13:28:02 miniupnpd[3440]: Listening for NAT-PMP/PCP traffic on port 5351
