Router's GUI missing elements
gil80
Using Merlin 3004.388.9_2 on my RT-AX88U
Under the Network Map, I no longer see the Client Status/AiMesh/Etc.
I tried different browsers to no avail. Any ideas if it's a bug in the firmware?
The first idea is usually to refresh the browser:
Do a Hard Refresh of the Browser:
Windows/Linux: Hold down Ctrl and press F5 or Shift + F5.
Mac: Hold down Cmd and Shift and press R.
See if this allows the page to display properly.
Quick checklist:
  1. Is HTTPS access enabled?
    Some browsers or misconfigured settings may block HTTP content from loading within an HTTPS session.
  2. Have you installed any third-party plugins?
    Certain plugins can interfere with the web UI, preventing elements from loading properly under HTTPS.
  3. Have you trusted the HTTPS certificate?
    If the certificate isn’t trusted, the browser may block or partially load the interface.
