Routing issues with multiple vpn client and multiple devices
pikachu123
Hello, I have ASUS RT-AC86U router and asus merlin version 384.19.
I have two Open VPN client profiles running in the router and I have following device routing requirements -
1. Device1 to route via VPN1
2. Device 2 to bypass any VPN
3. Device 3 to bypass any VPN
4. All other devices to route via VPN2
With these requirements, I have configured policy rules (strict) on my VPN profiles like below -
For VPN 1 -
Rule 1 - Device1 IP goes via VPN iface
For VPN2 -
Rule 1 - Device2 IP goes via WAN iface
Rule 2 - Device3 IP goes via WAN iface
Rule 3 - 192.168.1.0/24 goes via VPN iface
I have ensured these devices have manually configured IPs in the DHCP setting.
I am facing issue that sometimes Device2 is being routed via VPN. Can someone confirm if my rules configuration is correct? Is there any better way to fulfil the routing requirements?
just in case, check this one:
especially Jack Yaz 's answer
For VPN 1 -
For VPN2 -
You can use this one-line command to verify the actual Selective Routing rules when 'Device2' is incorrectly routed via the VPN
echo RPDB "Rules";ip rule;for I in 1 2 3 4 5;do echo VPN Client ovpn$I;ip route show table 11$I;echo;done;echo "WAN";ip route | grep -E "^0\.|^128.|^default" | sed '/^default/ s/[^ ]*[^ ]/xxx.xxx.xxx.xxx/3'
