whsbuss
I have Verizon FiOS and their ActionTec router. Currently I have an Asus RT-AC68U router set in AP mode connected as a subnet off the Actiontec router. I'm testing a Cisco router connected w/double NAT (need guest networking) on a different subnet.
Using my test Cisco E4200 router WAN->ActionTecLAN setup works well: any connected device on Cisco can connect to the Internet and NAS, printer, cameras on ActionTec subnet. What does not work is connection/pinging from ActionTec subnet to Cisco subnet.
Here's my config:
192.168.1.1 - ActionTec router
192.168.1.50 to 254 ActionTec DHCP range
192.168.1.33 static IP for WAN on Cisco, with 255.255.255.0 and gateway 192.168.1.1
192.168.100.1 Cisco LAN IP
I also set a static route in the ActionTec (Advanced->Routing->AddRoute) which is 192.168.100.0, 255.255.255.0, Gateway 192.168.1.33, Metric 0
With a PC connected to the ActionTec LAN pinging the IP for the Cisco WAN (192.168.1.33) never responds. And of course pinging 192.168.100.1 fails as well.
I think I need an additional static route on the ActionTec but not sure what is should be. The ping packets show a redirect to the 1.33 IP and then a Src and Dest with the correct IPs.
Here's my config:
