Routing Via GUI Ineffective, What Am I Doing Wrong?
Kevin K
When I create a route via the GUI:
  • Network/Host IP = 192.168.4.0
  • Netmask = 255.255.255.0
  • Gateway = 192.168.2.4
  • Metric = 1
  • Interface = LAN
  • Click "+"
  • Click APPLY
it doesn't show up in the routing table when I connect via ssh and run the route command.
What am I misunderstanding? Is there a way to enter the equivalent of
route add -net 192.168.4.0 netmask 255.255.255.0 gw 192.168.2.4
via the GUI?
EDIT: Is your router's LAN 192.168.2.x? If not the route is invalid.
You don't appear to be doing anything wrong. That's a pretty straight forward and simple option that's always worked in the past. Perhaps it's a bug in a particular firmware version.
What router and firmware are you using?
Is your entry still present in the GUI if you navigate away and then back to that page?
Are there any messages in System Log - General Log when you apply the route?
Does the route appear in System Log - Routing Table?
ColinTaylor: Thank you for the reply.
No. The router on which I am entering this route has a WAN address of 192.168.2.8. Maybe we're just missing on vocabulary. I think the GUI fields I mentioned above are the equivalent of the command-line route I mentioned above, and the command-line route sets up the desired route and the route works, so the addresses are right. I'm just trying to figure out why the GUI command does not have the same effect.
AC68, 384.19
Yes. It is also persistent through a router reboot, so it really is saved.
When I apply the route, there are plenty of messages because it restarts networking, but I don't see any errors from route or related to the addresses in that route.
Aha! It does not. System Log > Routing Table does match what I see when I run 'route' from the command line.
So that brings up a new question: Why does a route I apply via LAN > Route, not show up in System Log > Routing Table?
There's something about that route in particular. And... That's it. Apparently, the route command is defaulting to WAN. The GUI clearly defaults to LAN. Changi
  • Interface = LAN
to
  • Interface = WAN
fixes it.
Thanks for the help!
Glad to hear you got it working.
FYI. The route command isn't defaulting to WAN, it's just that you didn't specify an interface and it knows that 192.168.2.4 is part of the WAN subnet. The problem you initially had was that you were explicitly saying in the GUI that 192.168.2.4 was part of the LAN, which if course it isn't.
