Routing VPN traffic only for a particular port
WuTang LAN
On my PC I have Plex running which works fine expect for remote access from outside of the LAN.
I have port-forwarded the port used by Plex and I have added a rule in the custom VPN config
route plex.tv 255.255.255.255 192.168.1.1
neither have made my server accessible from outside the LAN.
I suspect it's to do with the VPN as I route all traffic to and from my PC through the VPN.
I would obviously rather not have to route all traffic through the WAN as this negates using a VPN. Is there anyway to keep all traffic on my PC routed through the VPN except for Plex?
I know that you can route all traffic for an entire device through either the WAN or the VPN, but what about just for a particular port?
Thank you for the link, octopus.
I have read through the information and hopefully I have understood it correctly.
Does the below look correct for routing all traffic on source port and destination port 32400 through the WAN?
#!/bin/sh
sleep 10  # During the boot process nat-start may run multiple times so this is required
# Ensure duplicate rules are not created
for VPN_ID in 0 1 2 3 4 5
   do
      ip rule del prio 999$VPN_ID  2>/dev/null
   done
# Create the RPDB rules
ip rule add from 0/0 fwmark "0x8000/0x8000" table main   prio 9990        # WAN   fwmark
ip rule add from 0/0 fwmark "0x7000/0x7000" table ovpnc4 prio 9991        # VPN 4 fwmark
ip rule add from 0/0 fwmark "0x3000/0x3000" table ovpnc5 prio 9992        # VPN 5 fwmark
ip rule add from 0/0 fwmark "0x1000/0x1000" table ovpnc1 prio 9993        # VPN 1 fwmark
ip rule add from 0/0 fwmark "0x2000/0x2000" table ovpnc2 prio 9994        # VPN 2 fwmark
ip rule add from 0/0 fwmark "0x4000/0x4000" table ovpnc3 prio 9995        # VPN 3 fwmark
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.10 -p tcp -m multiport --dport 32400 -j MARK --set-mark 0x8000/0x8000
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.10 -p tcp -m multiport --sport 32400 -j MARK --set-mark 0x8000/0x8000
I have created nat-start which looks like this
#!/bin/sh
   do
   done
iptables -t mangle -A PREROUTING -i br0 -s 192.168.1.10 -p tcp --dport 32400 -j MARK --set-mark 0x8000/0x8000
iptables -t mangle -A PREROUTING -i br0 -s 192.168.1.10 -p tcp --sport 32400 -j MARK --set-mark 0x8000/0x8000
When I do
iptables -nvL PREROUTING -t mangle --line
it shows that no traffic is being redirected through the WAN
Chain PREROUTING (policy ACCEPT 785K packets, 756M bytes)
num   pkts bytes target     prot opt in     out     source               destination
1     280K  207M MARK       all  --  tun11  *       0.0.0.0/0            0.0.0.0/0            MARK xset 0x1/0x7
2    3589K 4945M BWDPI_FILTER  udp  --  eth0   *       0.0.0.0/0            0.0.0.0/0
3        0     0 MARK       tcp  --  br0    *       0.0.0.0/0            0.0.0.0/0            source IP range 192.168.1.10-192.168.1.10 orts 32400 MARK or 0x8000
4        0     0 MARK       tcp  --  br0    *       0.0.0.0/0            0.0.0.0/0            source IP range 192.168.1.10-192.168.1.10 orts 32400 MARK or 0x8000
When I first created the nat-start script, it was working as intended very briefly- approx an hour before it no longer worked.
Please could one of you brain boxes assist?
