Routing WIFI clients through secondary internal router?
mustavas
Hi Everyone,
This is my first question here to go easy on me!
I have an ASUS DSL-AC68U running my internet connection and majority of my LAN clients.
Unfortunately like many here, I find myself limited by the stock firmware and am unable to use any alternatives like Merlin.
In a nutshell, I want to run a open connection VPN to PIA for all traffic except 1 or 2 hosts on my network (e.g gaming pc) and I am not easily able to do this with the DSL. AC68U .
I have a pfsense server running on an ESX host that works will for any VM on my host...is there anyway that I can route devices connected via wifi through my pfsense VM?
I would also be happy to run my VPN at a router level if I could exclude a specific client :)
Thank you for any advice!
Part of the problem here is that your DSL-68U is also your modem...
For many - I would suggest putting the pfSense instance as the gateway, but not as an ESX instance...
(pfSense is a great gateway/firewall, but as a virtual instance, one can't depend on their protection, and VMWare has had their issues)
indeed! this certainly is proving itself to be an issue.
I am focused on getting the routing sorted before worrying about security. My initial thoughts are that have separate vswitches for lan/vmkernel interfaces and WAN traffic should minimize exposure as well as some other hardening that I will follow once the concept is working.
