RSSI data for AiMesh Node devices
Igor
Two RT-AX68U (fw 388.1) routers are in AiMesh mode. The "Main_WStatus_Content.asp" menu (System Log->Wireless Log->Wireless 2.4 GHz) displays only those Wi-Fi devices that are connected to the master/main AiMesh router. How to find "Rx/Tx & RSSI" parameters for devices connected to a AiMesh Node?
Igor
iwconfig - not found
wlanconfig - not found
#nvram get wl_ifnames
eth5 eth6
#wl -i eth5 assoclist
#wl -i eth6 assoclist
These commands only output the addresses for the main/primary AiMesh. Node addresses are not shown.
lamp
You may want to download the stalist.sh script from https://github.com/megalloid/bcmdhdscripts
Then, ssh to the mesh node after you ssh to the mesh router.
In my case, I ssh to my node (ET8). Interestingly only the node interface has wl0.1 wl1.1 etc, my 5Ghz clients is on wl1.1
so I run
/jffs/scripts/stalist.sh wl1.1
Igor
main# /jffs/scripts/stalist.sh eth5
Noise and RSSI levels:
| AID |  Noise floor   |  RSSI (last frame)  |   RSSI (avg.)
   34    -96 -97 -97 0     -47 -41 -41 0        -47 -41 -41 0
   33    -96 -97 -97 0     -41 -36 -39 0        -37 -33 -36 0
   32    -96 -97 -97 0     -59 -55 -59 0        -59 -55 -58 0
   29    -96 -97 -97 0     -73 -58 -65 0        -70 -56 -62 0
   27    -96 -97 -97 0     -32 -28 -29 0        -31 -27 -29 0
   26    -96 -97 -97 0     -40 -41 -39 0        -42 -44 -42 0
   24    -96 -97 -97 0     -75 -74 -79 0        -73 -73 -78 0
   20    -96 -97 -97 0     -62 -56 -63 0        -62 -56 -62 0
node# /jffs/scripts/stalist.sh eth5
The GUI on the node shows that there are two Wi-Fi devices (and this is correct).
UPD.
The node has interface wl0.1. Yes, devices are visible there. Thank you!
