Hi...
Just upgraded my RT-66U to 380.61 and went to setup Duel Wan Failover with WAN and PART4 as WAN. It will failover to the second WAN port, but it will not pass data. It just says WAITING FOR "whateversite". If I put back the WAN1, it goes back and works just fine.
The 2nd WAN port (port 4) does show correct information in regards to the DHCP settings it receives from the Internet connection. (Raspberry Pi2 acting as a router handling out DHCP that then connects to a JetPack via USB. This is how I get around USB not working in the router. Very stable if used in the WAN port, so I would not expect it to be different as a failover.)
Just wanted to mention it and see if there was any thoughts on it.
Thank you.
Thank you.
