RT-AC1900P wifi question
dieter
I have a RT-AC1900P and using all ports and WiFi. I'm using AsusWRT. I would like to add a managed switch and move some of my wired clients to a VLAN on this switch. I also have a spare Dlink DIR655 WiFi - N router.
Can I make a WiFi client on the RT-AC1900P a part of a VLAN on the switch? I don't think so.
Can RMerlin firmware accomplish this without having to use the DIR655?
Should I use the RT-AC1900P and connect it to the internet, connect the switch to the RT-AC1900P, and use the DIR655 as the access point on the switch? Or would it be better to use the DIR655 to connect to the internet?
I have found several discussions on this subject. No responses need to my question...
