RT-AC3100 - CPU 1 at 100%
Nodiaque
Hello,
I'm having a weird issue since firmware 384. After some days, the CPU #1 stay at 100% all the time. If I try to reboot the router, it will freeze (the sequence seems to start, my network connection is lost but it never come back, I have to unplug the router power). I'm also using the FreshJR QOS script for 384. Does anyone saw this? Right now, I schedule a reboot everyday and it seems to mitigate the issue.
Thank you
Hello,
Thank you
Backup your setting. Reset router to default then reload your settings. Seemed to fix it on my router. Hope it works.
try
power off the router for 30 sec - 5 min
hold wps button while powering on, wait till the led to start blink then release to clear the nvram
it works for me
