GnatGoSplat
My RT-AC3100 was working perfectly on one of the 385 builds, didn't make note of which one, but probably the last one. I noticed there was a newer firmware version, so I let the router update like I have so many times before with no issues. My router updated to 3.0.0.4.386_41700 and now I cannot access wireless clients by hostnames on my LAN. I did do a full factory reset and manually (painfully) reconfigured everything from a fresh start, which did NOT fix the issue.
All my machines are on Windows default networking settings. 3 run Windows 10 20H2.
Wired computers can access the wifi computers via RDP, network share, and ping if I append a period (.) to the end of the hostname. From what I've read, this means it's failing NetBIOS or WINS name resolutions.
I've tried all number of ipconfig /flushdns, ipconfig /renew, on all the machines. I've tried rebooting them all. ipconfig /all looks no different between any machines.
Running "nbtstat -a <ipaddr>" from a wired machine does return the NetBIOS machine name in the "NetBIOS Remote Machine Name Table".
As mentioned before, factory reset was attempted and didn't help.
Any ideas? I haven't tried downgrading back to 385, but I will later.
- Computer1 - Wired - Can access Computer2 via hostname (ping, access Windows shares, RDP, all works). Cannot access Computer3 or Computer4 with hostname.
- Computer2 - Wired - Can access Computer1 via hostname (ping, access Windows shares, RDP, all works). Cannot access Computer3 or Computer4 with hostname.
- Computer3 (Windows Server 2019) - Wifi - Can access Computer1 and Computer2 via hostname (ping, access Windows shares, RDP, all works). Cannot access Computer4 with hostname.
- Computer4 - Wifi - Can access Computer1 and Computer2 via hostname (ping, access Windows shares, RDP, all works). Cannot access Computer4 with hostname.
