Sinner
Hey guys.. recently purchased an asus rt-ac3100. specs and hardware appear to be amazing and I'm running the latest merlin on it..380.68_2... appears to be running stable but I keep experiencing periodic lags or something I never experienced with my ancient Linksys E3000. Out in the country here so no major interference and running behind another cellular modem/router(zte mf275r). Are there any particular settings that come to mind for this setup other than disabling firewall on the rt-ac3100? ive pretty much disabled everything I'm not using.
would also like to add I'm noticing some strange logs suggesting the time on it may not be working right. it appears to be correct everytime I log in to check it but logs look like as soon as I'm not looking it forgets lol. heres an example :)
Sep 30 11:01:10 kernel: gro disabled
Jul 31 20:00:14 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Jul 31 20:00:14 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jul 31 20:00:14 kernel: Machine: Northstar Prototype
Jul 31 20:00:14 kernel: Ignoring unrecognised tag 0x00000000
Jul 31 20:00:14 kernel: Memory policy: ECC disabled, Data cache writealloc
Jul 31 20:00:14 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Jul 31 20:00:14 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06, pc=0x8000f9d8 lr=0x8000f9cc ignored.
Jul 31 20:00:14 kernel: Mount-cache hash table entries: 512
Jul 31 20:00:14 kernel: CPU1: Booted secondary processor
Jul 31 20:00:14 kernel: Found a Zentel/Esmt NAND flash:
Jul 31 20:00:14 kernel: Total size: 128MB
Jul 31 20:00:14 kernel: Block size: 128KB
Jul 31 20:00:14 kernel: Page Size: 2048B
Jul 31 20:00:14 kernel: OOB Size: 64B
Jul 31 20:00:14 kernel: Sector size: 512B
Jul 31 20:00:14 kernel: Spare size: 16B
Jul 31 20:00:14 kernel: ECC level: 8 (8-bit)
Jul 31 20:00:14 kernel: Device ID: 0xc8 0xd1 0x80 0x95 0x42 0x7f
Jul 31 20:00:14 kernel: bio: create slab <bio-0> at 0
Jul 31 20:00:14 kernel: PCI: no core
Jul 31 20:00:14 kernel: PCI: Fixing up bus 0
Jul 31 20:00:14 kernel: PCI: Fixing up bus 1
Jul 31 20:00:14 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jul 31 20:00:14 kernel: pflash: found no supported devices
Jul 31 20:00:14 kernel: bcmsflash: found no supported devices
Jul 31 20:00:14 kernel: Boot partition size = 524288(0x80000)
Jul 31 20:00:14 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Jul 31 20:00:14 kernel: === PPTP init ===
Jul 31 20:00:14 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Jul 31 20:00:14 kernel: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Jul 31 20:00:14 kernel: Available 7 bytes at (off,len):
Jul 31 20:00:14 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Jul 31 20:00:14 kernel: Options: NO_AUTOINCR,NO_READRDY,
Jul 31 20:00:14 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Jul 31 20:00:14 kernel: et: module license 'Proprietary' taints kernel.
Jul 31 20:00:14 kernel: Disabling lock debugging due to kernel taint
Jul 31 20:00:14 kernel: et_module_init: passivemode set to 0x0
Jul 31 20:00:14 kernel: et_module_init: txworkq set to 0x0
Jul 31 20:00:14 kernel: et_module_init: et_txq_thresh set to 0xce4
Jul 31 20:00:14 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Jul 31 20:00:14 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Jul 31 20:00:14 kernel: et_module_init: et_rxlazy_dyn_thresh set to 0
Jul 31 20:00:14 kernel: fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.56 (r641653)
Jul 31 20:00:14 kernel: fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.56 (r641653)
Jul 31 20:00:14 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.56 (r641653)
Jul 31 20:00:14 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 31 20:00:14 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Jul 31 20:00:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:188 started
Jul 31 20:00:14 kernel: Dongle Host Driver, version 1.363.45.58013 (r651509)
Jul 31 20:00:14 kernel: Compiled in drivers/net/wireless/bcmdhd on Jun 15 2017 at 08:42:46
Jul 31 20:00:14 kernel: Register interface [eth1] MAC: 70:8b:cd:d0:08:88
Jul 31 20:00:14 kernel: PCI: Enabling device 0002:01:00.0 (0140 -> 0142)
Jul 31 20:00:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:18e started
Jul 31 20:00:14 kernel: Register interface [eth2] MAC: 70:8b:cd:d0:08:8c
Jul 31 20:00:14 kernel: Empty flash at 0x03e40a94 ends at 0x03e41000
Jul 31 20:00:20 syslog: module ledtrig-usbdev not found in modules.dep
Jul 31 20:00:20 syslog: module leds-usb not found in modules.dep
Jul 31 20:00:20 kernel: csw_retry 100
Jul 31 20:00:21 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jul 31 20:00:21 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jul 31 20:00:21 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Jul 31 20:00:23 kernel: nf_conntrack_rtsp v0.6.21 loading
Jul 31 20:00:23 kernel: nf_nat_rtsp v0.6.21 loading
Sep 30 11:03:27 crond[540]: time disparity of 1139943 minutes detected
The log indicate the router was rebooted, which is why the clock got reset, until it reconnects to the Internet, so it can retrieve the correct time using NTP.
yes you are correct I had recently done that but I guess my concern in the logs multiple times a day I'm seeing way off dates and then getting corrected.. but id also like to mention after doing the 30/30/30 for the 5th time I think I may have found a stable setup here. still need to do more performance testing because it feels sluggish or possible just dns related do to me being dbl nat atm. ill get back to you on that and then might as well close thread.. it was in the wrong section anyway.. sorry I don't hang in forums much :)
I'm just amazed at all these issues.. like awesome visual desing, bleeding edge hardware and asus always makes amazing quality stuff. thes issues shouldn't be.. I love this router but everything in my guts telling me to return and go back to Linksys because they'll likely never fix it perfectly
